Old 09-06-2010, 08:18 AM
fleetus macmullitz's Avatar
Yeah!
Old 09-06-2010, 08:48 AM
Cris@JCG's Avatar
Cris@JCG Cris@JCG is offline
Default rear qtr stretch update
Here is the latest update on the rear qtrs... We are finishing up all the small details.. We will be starting the front fenders this week..
Cris Gonzalez
Old 09-06-2010, 08:55 AM
Roadbuster's Avatar
Roadbuster Roadbuster is offline
Looking good! That quarter looks factory. It will cause a lot of head scratching as people will look at it and say its different but how? And how did you fit those tires?
Jon U.
1968 GTO - SC&C's suspension
1967 911 - a few modifications
Old 09-06-2010, 08:56 AM
Cris@JCG's Avatar
Default Shifter tunnel plates
Here are some plates that we machined last week for the shifter.. The transmission tunnel is almost done.. but need these pcs to complete it..
The thin steel ring will be welded to the tunnel & the aluminum plate will give it access thru the top to remove the shifter when tranny needs to removed...
Cris Gonzalez
Old 09-06-2010, 10:13 AM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Killer work Cris. Keep us posted bud!
Old 09-07-2010, 10:29 PM
itsals1 itsals1 is offline
Cris, Was the fender strech this way vs. the way it was on TrackRat a better way to go? It almost seems ashame to cut up and toss out good factory qtrs .
Travis
Old 09-08-2010, 08:25 AM
Cris@JCG's Avatar
This stretch is totally different from what we did to Track Rat... One of the things I did not like from when we started doing this body modifcation was that it was rasing the body line & the wheel well opening... The way it is done on this car it less noticable that the qtr was widen up..
This car needed both qtrs replaced.. plus one of the reason I got the project was because the customer wanted all four corners blown out..
Travis
Cris Gonzalez
Old 09-08-2010, 08:56 AM
Cris,
Do you think this is as wide as you'll mod any future builds?
Old 09-08-2010, 09:04 AM
Thanks for explain . I was hoping to do the qtr./fender stretch on my 67', BUT I think my qtrs. are in good condition so was hoping to use the orginals. Well I'll cross that bridge when I can afford it, Thanks for the info.
Travis
Old 09-08-2010, 09:46 AM
Cris@JCG's Avatar
I got another 68 Camaro that we are widen up!! Using a C6 Corvette suspension... We are building the chassis & suspension first .. Then doing the body modifcations...
Originally Posted by compos mentis View Post
Cris,
Cris Gonzalez
