Old 09-14-2010, 09:32 AM
67ragtp 67ragtp is offline
I have to wonder WHY you want this "gook" in the first place?? Personally there's no way I'd use any of that kind of stuff in a modern built car.
Just asking.
Here's my logic(sometimes twisted), The two big connectors on the outside(engine bay) of the fuse box are exposed to the elements. I pulled many of the circuits out of the engine harness side connector(lots of efi sensors). It now has lots of open spaces where water can easily get in. The dielectric grease seals it up and prevents corrosion. Just looking for a non melting dielectric grease, fairly common for this application. The old brown gook seems to really last. Im not sure how other company's or newer style fuse panels seal up the weather side of there fuse boxes can only tell you that the classic update harnesses from AAW do not have any sealer in them. Im thinking about some long haul trips eventually and Im sure there will be rain/water potentially in this area.
Rich
Old 09-14-2010, 10:40 AM
GM Muscle's Avatar
ive used the liquid electrical tape several times to fil in pins where wires were removed before.. worked fine for me.. i think i actaully bought it at lowes.
'69 Camaro- Daily Driver
'70 Chevelle- Project
Old 09-14-2010, 01:31 PM
ccracin's Avatar
ccracin ccracin is offline
Rich
AAW is a vendor here. Call them and I would think they could give you some info.
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 09-14-2010, 08:02 PM
Wouldn't you install a blanking plug into those open holes ? I've seen the weatherpack style plugs. They should be available from the vendor/manufacture of the component. Contact AAW like Chad said
Jim
My Project: 65 Porsche 356G
https://lateral-g.net/forums/showthread.php4?t=5109
Old 09-14-2010, 08:10 PM
already contacted them., all they said is that its a GE product, didn't want to give me the product name I guess. did some searching but couldn't find a product name.
No biggy, Ill find something suitable to seal it up.
Thanks Rich
Old 09-14-2010, 09:10 PM
Rich -- The reason I was asking is that sometimes if others know what you're trying to do - they can offer an alternative suggestion.
Now we know! LOL
You don't want to use some silicone sealant?
Old 09-18-2010, 08:59 AM
JamesJ JamesJ is offline
I have used the permatex stuff and works pretty good, that brown stuff is great! If you find it post it up, I use it on our motorhome battery and boats and that kind of stuff
http://www.amazon.com/American-NA60-.../dp/B001BB3DLU
http://www.acehardwaresuperstore.com...30.html?ref=42
James J.
