Old 09-29-2010, 10:50 AM
You probably already know this -- but DO NOT ball the tungsten for aluminum.
I run into this all the time with newb TIG welders... and without looking up your model -- IF it's an INVERTER style machine - you don't ball the tungsten when using them. Sharpen and knock the sharp point off...
I use the CERIATED tungsten now with my inverter type TIG not the pure (green end).
Old 09-29-2010, 01:25 PM
ccracin's Avatar
ccracin ccracin is offline
This is not an inverter machine. It is a square wave. The Lincoln guy said I would have to ball the tungsten for Aluminum on this machine. So far the consensus is that if I got Ceriated or Lanthinated, I would be better off. Should have the new Argon bottle in a day or so. We'll see! Thanks as always!
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 09-29-2010, 02:32 PM
Ah ha.... that makes a difference for sure.
I'm a Miller guy... so wasn't familiar with that version and I'm no pro that's for sure.. but it sure is a common "mistake" with these newer style machines.
Old 09-29-2010, 08:04 PM
ccracin's Avatar
Well I fired up the new welder tonight. I think they lied and sold me a plasma cutter instead! LMAO I got better as I played. This is going to take some practice! Woo
Chad
Instagram - @cctek
