Old 10-11-2010, 02:28 PM
RBR's Avatar
RBR RBR is offline
Default Kwik Performance Brackets?
Has anyone used this bracket to relocate their pwr steering and alt. I was looking into getting a new corvette surpentene drive from PACE and found these brackets that do the same and use your existing pwr steering and alt. It is about half the cost of a complete kit that comes with eveything from PACE.
Old 10-11-2010, 04:54 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
Haven't used that setup, but I did get their AC compressor mount for use with a Corvette LS3 serpentine setup and was very impressed with the brackets. The hardware (nuts and bolts) could be prettier, but that's a minor quibble. One of the few aftermarket parts I've gotten that just bolted on and worked without modifying something.
Old 10-11-2010, 05:05 PM
Grnova's Avatar
Grnova Grnova is offline
I am using them on my LS2. Fitment is nice. My application is a little different. The bracket across the water pump is from KB.
Old 10-12-2010, 09:31 AM
RBR's Avatar
RBR RBR is offline
Thank you for the replies and the PIC. I think I'm going with them!
Old 10-12-2010, 07:41 PM
aany001's Avatar
aany001 aany001 is offline
I used their ac compressor relocation kit on my LS1 and it worked slick but I agree that the hardware could be switched out to something nicer.
Old 10-13-2010, 12:11 PM
RBR's Avatar
RBR RBR is offline
Default Alt holes measurement?
I called Kwik today to try and get measurements of the alt mounting holes. I wasn't able to get anyone on the phone, so I just left a message. I haven't got a reply yet.
Does anyone have the distance from the mounting holes of the alt? I have a ctsv set up from PACE and want to make sure it is the same before I order. I called PACE they sell kwik as well but they were unsure of the measurement and did not have a unit to measure for me.
Old 10-25-2010, 03:00 PM
TexasHM TexasHM is offline
I'm friends will all of the guys at KWiK. I'll send them a link to this thread and maybe you can get your answer that way. I do know that they are quite busy.
Mike
Old 10-26-2010, 09:53 AM
RBR's Avatar
RBR RBR is offline
Default KWIK called me back
Thanks Mike, I did get a return call and I should have posted that I did. I decided to go with with a complete kit that has alt and pwr/steering pump. I got lazy and didn't want to have make my parts work.
Old 11-21-2010, 09:43 PM
customshop1 customshop1 is offline
i have used the Kwik parts and fit great very good product for the price.
Wayne has a lot of great knowledge as far as fitments go also.
you will be happy with them. good luck. we used them on our green lime time camaro LQ9 motor.
Old 11-22-2010, 06:17 AM
Wayne is a literal encyclopedia with cars. His knowledge is unbelievable....
