Old 10-24-2010, 06:49 PM
bdahlg68's Avatar
bdahlg68 bdahlg68 is offline
Default Moving along...
So I'm plugging along as I get time. Most panel removal is complete. The problem is that the more I pull off, the more I want to replace. Ugh. Drip rails weren't that concerning, but now I think I'm going to replace the trunk pan. It's solid, but pitted way more than I expected. I went at it with a rust remover pad on my grinder, made a big mess, but not much progress on the rust. The main problem is that I want to do a AME rear suspension and am starting to worry about getting the panels lined back up. Especially as I keep pulling off panels! Anyone have any experience with this? Any input would be much appreciated.
Old 10-24-2010, 10:15 PM
Tuske427's Avatar
Tuske427 Tuske427 is offline
As I'm doing my car, I'm trying to fix one area at a time. This way, the rest of the car is still there to support and align things.
Because most of yours is apart, I recomment a lot of cleckos and sheet metal screws to temporarily put it back together before you weld everything up. The current and last month's issue of Car Craft covers a shop rebodying a 68 mustang coupe into a fast back. Many of the technical "how to" may be of help for you.
I hope this is helpful
Keep the pics coming!
Long Live the Muscle Car
https://lateral-g.net/forums/showthread.php4?t=26338
Instagram: @tuske427
Old 12-04-2010, 05:44 PM
bdahlg68's Avatar
Doesn't look like they braced too much, just fit everything with screws. Makes me feel better as I want to get the floors and mini tubs done while the car is apart.
I'm starting to wish I just saved and bought a Dynacorn shell. Although I'd still end up hacking it apart to do the mini tubs and rear suspension. I hope once I'm finished, I feel like I made the right decision.
Old 12-04-2010, 09:17 PM
elitecustombody's Avatar
Looks like you got your hands full, whatever you do, don't give up.Try to weld braces to keep the rest of it in shape. Post more pics of the progress.If you need a good deal on AMD sheetmetal,let me know, I'll hook you up.
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 12-12-2010, 07:49 AM
Jim Nilsen's Avatar
Jim Nilsen Jim Nilsen is offline
I held mine together with screws so I could adjust if i needed. I used a laser level for ceilings to make sure my panels were all in the same plane as my rockers and then measured side to side and square then welded it up slowly with a bunch of tacks to start and then when it all fit just right I did the final welding. The laser showed me where to raise or lower the rear of the panels to keep them from sagging dowm wich they wanted to do naturally it seemed. The shape of the rear quarter even looked better when it was lifted in the rear to make the body line all the same.
I never used any bracing inside and the measurements never changed, I didn't use a rotisserie which definately requires bracing. When all of the gaps and lines look right it doesn't matter if the car shifted the way I see it, the car could have been off from the factory and cause you problems trying to line things up that will never be right till you shift the car.
I would replace that trunk pan if it was me, but if not you better get something on it like POR or something to stop it forever.
May the Horsepower Be With You !!!!
Old 12-18-2010, 12:04 PM
bdahlg68's Avatar
Last business trip of the year is done! A new record for me though. 129k miles on Delta. Hopefully next year isn't quite so hectic.
Anyway, on to the car. I got the drip rails and roof test fitted. Just sheet metal screws for now as I wasn't sure how to position the drip rails. The drip rails seem to be in pretty much the right spot (driver side may need to slide forward just a touch). The passenger side roof corner at the A-pillar doesn't seem to fit too well. Maybe some trimming is in order? I can squeeze it down flush but it is TIGHT. Also, the roof to drip rail support on the driver side is a bit off it seems. I'm hoping that sliding it forward helps that and putting in a few more sheet metal screws to really hold everything in place.
I also threw one of my G8 summer wheels under there for some inspiration. Looks good!
Old 12-30-2010, 03:35 PM
bdahlg68's Avatar
Adjusted the drip rails a bit and I'm pretty happy with the roof fitment. Also, first VERY ROUGH placement of drivers quarter. Still cleaning up around rear panel and filler panel before it will fit correctly and hopefully relatively easily.
I also ordered nearly everything else I need to put the back half of the car back together. After it's all installed, I'll probably pick up the rear suspension and install that before moving on to the floorpan / front end.
Old 01-11-2011, 04:52 PM
bdahlg68's Avatar
Got a nice delivery from Classic Industries today. Inner Cowl, DSE Firewall Fill plate, outer wheelhouses, tail panel and brace, rear valence, full trunk panel and side panels. Nearly everything I need to have a complete shell from the firewall back. I feel like a Firebird parts warehouse!
Still need floorpan, Anvil trunklid, and dash panel to finish the shell. That will be ordered after the Speedtech rear suspension I'm planning to order late February timeframe. Trying to get as many parts around me as possible so that I'm never waiting on them. Now it just needs to warm up in my garage!
Old 01-11-2011, 05:11 PM
68FBODY 68FBODY is offline
Looking good! Firebirds are popping up on here more often now
1968 Firebird Pro-Touring project
1967 Mustang Fastback Pro-Touring project
Old 01-11-2011, 05:35 PM
Ron Fox's Avatar
Ron Fox Ron Fox is offline
Nice Project!
Keep up the good work.
Ron
1969 Firebird, 4-speed Coupe
