Old 11-08-2010, 07:44 AM
Northeast Rod Run's Avatar
Northeast Rod Run Northeast Rod Run is offline
I did have it staked down at each of 8 posts and had two cinderblocks at each post also.
Looks like the rain is letting up so I can go out there and see if it is saveable or not. I do know that the top post, that goes along the whole length is bent from where it wrapped around the tree.
I need to try and save more money so I can build the addition to my garage sooner than I wanted to
TJ Ragucci
http://www.northeastrodrun.com/
Old 11-08-2010, 08:14 AM
I know how you feel storing a car outside. I did it with the Camaro for a while. I got lucky and found a reasonably priced garage where the owner worked out of his yard and watched it for me. I used a car cover and then a poly cover over that. But the car was still in ruff shape at the time.
