Old 11-18-2010, 06:49 AM
NAPA 68 NAPA 68 is offline
Default Driveshaft Length
What experience have some of you had with the maximum length for a 1 pc. driveshaft? As some of you may have seen, I am in the process of building a 59 Bel Air. I was curious what the parameters are for determining when a person should have a 2 pc. shaft. BTW, the car will require a 57" shaft center to center on the yokes.
Thanks,
Tim
Old 11-18-2010, 01:25 PM
61ragtop 61ragtop is offline
Not sure on the max length but you might obviously have an issue with the X frame unless you plan to custom build a frame. I think the Chicayne had a 2 piece still and they ran over 1100 hp through it with no problems.
Old 11-19-2010, 05:40 AM
I should have thought of that. Moose is a close friend of mine. I'll call him!
Thanks for helping me get my head out of my ass!
Old 11-19-2010, 04:40 PM
Hey no problem thats what we are all here for to help each other out!!
Old 11-20-2010, 05:15 PM
Napa ---
Here's a Rod and Custom article that gives you some food for thought.
http://www.rodandcustommagazine.com/...ech/index.html
Old 11-21-2010, 10:13 AM
rwhite692's Avatar
My 1960 Caddy had a two-piece (factory) and it was necessary...but that car was an all-stock restoration and had a lot of suspension travel...If you are setting your car to ride low and with not a lot of travel, you may be able to get away with a one piece...
You could pretty easily make a mock-up driveshaft (plastic pipe, etc) to check it out and see what your angles are, X-Frame center section tunnel interference, etc at min/max ride height.
Project update thread here:
My Lateral-G Page
My Shop Build:
