Old 11-30-2010, 06:54 PM
T-Type T-Type is offline
Originally Posted by elitecustombody View Post
D/A with 80 or blast it again. When done spray Picklex20 so you won't have to do it again
i may be missing the obvious here but could you explain what the difference is between epoxy primer and this picklex 20 stuff? is the picklex 20 better to use if the metal is going to sit around longer w/out coating vs. epoxy primer?
