Old 12-27-2010, 12:13 PM
Z06vette's Avatar
Z06vette Z06vette is offline
Thanks for all the help guys- switched the lines, all seems OK. Won't know for sure until its driveable. Ya- all these mix & match aftermarket parts has been a challenge. I think I'm past the worst. I bought a ford pressure line to use the fitting that goes in the rack- it could only fit in the larger threaded socket in the rack. So I ran the LS1 pressure line to that fitting, since bought a PRESSURE line. Go figure, its actually the return side of this rack. I still am not 100% on what rack this is, but it matched visually to 03/04 cobra. I have a wayne due subframe, and it came with the rack in it. Ford dealer couldnt help me identify it without the metal tag with a part #, which is not there. Well I can move forward again knowing the motor runs, no leaks, good oil pressure, etc. I really appreciate all the help and knowledge I gained from the site in the last couple years.
Old 12-28-2010, 07:00 AM
Payton King's Avatar
Default Glad you have it worked out
post up a picture of the rack. I am sure someone could identify it for you.
Old 12-28-2010, 09:11 AM
I did the same thing but blew my steering input seal. Only Ford would make a red fitting return and yellow pressure.
