Old 01-05-2011, 08:28 AM
130fe 130fe is offline
Thumbs up
There is a picture that might help you here: http://www.scaldinghot.com/gaugepage.htm If you are using the 5 inch ones, they should fit snugly in the factory bezel (I used to have the same setup in my car). They used to come with a U shaped piece of metal that you could shorten and hold it into the bezel. I had to get a replacement gauge and they sent a round mounting bracket that would not work. You could get some 1/2 inch metal bracket and bend it and modify it to secure it in place. Send me your email and I will try to send you some better pictures (they are on my home computer).
I have seen others that mount the gauges from behind the bezel. You have to slightly modify (so that the new guage bezels will fit inside the factory figure 8 piece and then that mounts to the back side of the factory bezel) the figure 8 shaped bracket that was origianlly used.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 01-05-2011, 10:12 AM
jdtrumbore jdtrumbore is offline
Thanks guys, those are both helpful to think about. I have the old style Autometer with bent aluminum bracket that I cut shorter. Gauge is installed from the front and they do fit reasonably well. I did not think of using the original bezel and will see if that helps with alignment and installing from the rear.
I also like your turn signal indicators. I was thinking along the same lines, but did not think about that location.
Old 01-05-2011, 11:01 AM
marks914's Avatar
marks914 marks914 is offline
Regular User
We are cutting some mounting brackets for our 5" 3-1 gauges. Should have them next week some time, will post pics when we have them ready. Should work for the Autometers as well.
Mark
www.newvintageusa.com
