Old 01-11-2011, 07:14 PM
LowchevyII's Avatar
LowchevyII LowchevyII is offline
Originally Posted by The WidowMaker View Post
70 chevelle is the man and has given me some advice and many ideas with his pictures. hopefully he will chime in with some answers for you.
but, i still dont see the need to worry about replacement panels. making a mold is a crap load of work and i just dont want to invest that much time. my basic frame will be mdf with a lot of material removed to save weight. then im going to do as i said above and just stretch fabric over it and apply some resin. i will probably come back and do a little glass work on the back to reinforce some areas. the goal is to do it with the least amount of sanding possible.
all of this will be negated for me if marquez comes out with their chevelle interior in the next 4 months or so.
Tim
thanks tim!. 70 chevelle is the man with those panels. I would love to see how youre going to do yours. maybe start a build thread with pics of the panels. I think i might use your route to avoid the molds becuase the more and more i think about it the more i feel like i need to listen to reason and not make them. I just want a modern look very similar to feslers stuff or in this case 70 chevelle's .
Jeff Weidner
1970 nova in pieces
Old 01-13-2011, 06:12 PM
ProTouring442's Avatar
I'm making my own for a '72 Olds. I'm using he blue foam you can buy at Lowe's with epoxy resin and glass mat.
Shiny Side Up!
Bill
Never met a man with real talent who felt the need to deride the efforts of other.
Old 01-13-2011, 07:53 PM
LowchevyII's Avatar
thanks Bill!...ill definitely be checking that out.
--Does anyone have any info on mounting the door pulls and the actual panels themselves for that matter?
Jeff Weidner
1970 nova in pieces
Old 01-14-2011, 05:49 PM
The door pull will need to mount in some way that is directly attached to the door, and not just the door panel. When I made the armrests in my father's '56, I used a 90* bracket that attached to the door, the armrest then slid over that, then the pull (a cup style) mounted down through the armrest to the 90* bracket.
As for attaching the door panel, I plan on using the stock christmas tree style clips along with a set of screws down under the door panel. These will be concealed by their position under the bottom curve of the panel, as well as by covers.
Shiny Side Up!
Bill
Old 01-14-2011, 07:39 PM
LowchevyII's Avatar
beautiful. thank you, Bill! I really appreciate the info.
same goes to all the others that have contributed thus far. Im always overwhelmed by the wealth of knowledge here.
Jeff Weidner
1970 nova in pieces
Old 01-14-2011, 07:41 PM
70 chevelle 70 chevelle is offline
Thanks guys I'm definitely no expert. The reason I made the molds was soley to vacuum bag the parts which made them lighter and stronger. I wanted sealed air space for midwoofers , I could not find a way to do this with mdf without the panels being stupid heavy. My car will not be a feather weight when its done but I simply refused to make 50 pound panels.
If your just making a specific shape and have no need for a double walled panel, I'm sure you can make some from mdf that would be a reasonable weight. As for mounting the I 'm using screws through the door pull hole and speaker access. If you look at the pictures the door pull screws directly to the mount which attaches to the door itself. Your never actually pulling on the door panel itself. the panel could just mount with screws but I did not want it to vibrate so the outer perimeter has the same material used to mount an Ipass to your windshield . Its strong stuff.
There is an interior thread on here started by the recovery room where he shared a few tips abut making the base panels from aluminum and how to mount them. There work is simply incredible and picking his brain would be the best thing you did.
Tony L
You can't fix stupid!
Old 01-15-2011, 10:29 AM
LowchevyII's Avatar
thanks tony! for not being an expert, your work definitely says different. thanks for all the advice, its much appreciated.
Jeff Weidner
1970 nova in pieces
Old 01-17-2011, 04:04 AM
lnirenberg lnirenberg is offline
Check this out--
http://www.pro-touring.com/showthrea...l-build-thread
Larry
1957 Pontiac Safari
2014 911 GT3
2006 Ram SRT-10
2014 MB E250
Old 01-17-2011, 08:48 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Me, myself...I'm going to buy the Fesler one's for my Chevelle. I've paid for a custom set of door panels before and they cost waaaayy more than $1100. About time you buy all the materials, pay for the labor and then pay for the upholstery you will have quite a bit of money in them. I think the Fesler one's are perfect for the price and they really look good. Although, Fesler doesn't make them production yet for your Nova check with him anyway. But, any custom stereo shop or custom upholstery shop can make them.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 01-23-2011, 11:55 AM
TheShopLLC.com TheShopLLC.com is offline
Default The Shop Llc Interior Build Pics
CLICK ON THIS LINK AND CHECK OUT JOSH AND NICKS 70 CHEVELLE, I POSTED OUR DETAILED INTERIOR BUILD FOR 70 CHEVELLE MAYBE IT WILL HELP YOU OUT.......GOOD LUCK IF YOU NEED ANYTHING GIVE US A HOLAR.....
THANKS.....THE SHOP LLC
http://www.hubgarage.com/mygarage
TheShopLLC.com
