01-07-2011, 10:37 PM
Originally Posted by Sieg
Ron,
Thanks for the thread, I've been researching and debating trannys for my '69 Camaro for a few years.
After reading all the good info in your thread..............I'm still leaning towards the T56 after having a .50 6th T56 in a '94 "Service Package" Camaro. Stielow's cars are my primary inspiration and he appears to have good success with T56's.
I have put my trans decision aside for now since it will be awhile before I need to make that decision.
I know it definitely wont be a Richmond  ...anyone seen Greg?
Ron
1969 Firebird, 4-speed Coupe
01-15-2011, 02:28 PM
Consider the KEISLER Rallye Sport 5-Speed
If you are looking for the shift quality of the T56 Magnum, you should check out our KEISLER Rallye Sport RS 5-speed. It utilizes the advanced synchro technology developed by Borg Warner and 3M for the T56 and T45. Parts are directly interchangeable with Viper T56, for example.
The RS shift quality is, in my opinion, better than the T56 because the linkage system in the T56 is massive for the 5/6/R shift rail system. The T56 was originally developed as a truck transmission for GM 1/2 called T55. It never went into production as a truck tranny, but kept the design.
The RS fits our muscle cars with no cutting in most applications - all GM F, A, X, and B-body. This is due to our new transmission case, along with the use of new PerfectFit designed shift components.
All RS transmissions come with a premium shifter mechanism: adjustable but preset solid shifter stops, tunable shifter bias spring (we select the right set for your application), bearing materials under all moving joints, sealed, and no plastic junk anywhere.
Pricing for RS 5-speed kits (incl new dynamic balanced driveshaft, crossmember, isolator, speedo cable/gear, pilot bearing, hardware, console nameplate or shift knob, fully illustrated instructions) starts at $2295 for the RS400 kit, $2595 for the RS500 kit, and tops out at $2995 for the RS600 close ratio 600 torque kit.
The RS uses your stock bell, clutch pressure plate (and fine spline GM disc for 500/600 models), put the shifter exactly in the correct shifter position, and includes a 3 year blanket warranty.
We have been selling the RS for 3 years now as the T45RS in the lower torque format, non PerfectFit design. The RS 5-Speed is a redesign of the T45RS with many new parts, including higher torque capacity 1pc shoot peened 9310 CNC ground gears among others.
RATIOS:
RS400/500 3.37, 1.99, 1.33, 1.0, .67
RS600 *best ratios* 2.80, 1.99, 1.33, 1.0, .67
Hope this helps to give you and everyone else here more insight to the RS, and more choices.
01-15-2011, 04:23 PM
Mini thread-jack
Shafi,
Are you going to have an all inclusive kit for us 67-69 Camaro/Firebird people that can't stand the embarassment of their automatic muscle car?
My goal is to get my '69 somewhat track day competent. Current 3:73 posi with Moser axles, 355 ci, 202 heads, GM "Duntov" cam, 650 Speed Demon, that comes to life around 3-3,500 rpm. Will the RS-5 600 close ratio gearing be a decent choice?
I had the car 21 years now and it's about time to increase her fun factor.
01-16-2011, 09:36 AM
Mini thread-jack
Shafi,
Indeed! Check out the complete solution HERE. I've attached a pic also.
Sounds like the Duntov cam is similar to the one used in the 327ci/365HP Corvette '63-67. I had a '65 Vette with this engine, and it liked to run above 3000rpm also. This motor will work exceptionally well with the RS500 deeper first gear. Those engines like to rev and can use the extra torque multiplication the lower first gear provides. That being said, the 2.80 first gear will motivate the car with less torque multiplication, but less drop in the 1-2. If you shift at 6500rpm, you'll be going 40mph with the RS400/500 and 48mph with the RS600.
Check out a really nice gear speed calculator here. Use the ratios to compare the two for your application.
01-16-2011, 10:05 AM
Thanks! I also have the 327/365 Vette heads. Appreciate the gearing input, most vehicles I've had, including bikes have typically had too low a 1st gear, lighting the tires or running out of rpm too soon, making short-shifting to 2nd the norm. Feathering the clutch a little adds to the experience.  I don't place much emphasis on city driving with the car as I'm in a small town, country roads is where I enjoy it. With 3:55's it could see the taller 1st being a problem, with 3:73's I'm on the edge in your opinion?
Sorry for the jack Ron, hopefully you get some info from the input.
01-16-2011, 01:28 PM
Thanks Keisler and Sieg. Keep the information coming. The more I hear the more I learn.
The RS 5-speed sounds like a good, all around choice. How many have been sold to this point?
Are there any guys here running the RS 5-speed?
Ron
01-16-2011, 04:18 PM
+1
01-16-2011, 04:58 PM
Im in a similar situation 3:73s . Right now I have a 700r4 a 3:06 first gear .
I do trackdays , HSAX stuff . I can usually get to the first turn in first with 330 HP . I will probably never have more than 400 HP at the rear wheels
Do I go with a rs400/500 ? or the rs 600, for the better first gear ?
Once under way I do not expect to need first gear with either trans
I did send Keisler a couple e-mails , no answer yet
01-17-2011, 11:09 PM
Hey Folks,
We've been selling the RS400 and 500 in the previous packaging T45RSxxx since 2007, and have hundreds of them in the market. With the new case, and close ratio high torque gearing, along with more than 15 PerfectFit versions came the RS last month. Our run rate on the RS now far exceeds that of the TKO, so we'll start seeing a lot more of these units in the field soon. There are T45RS owners here on Lat-g.
Regarding the gearing, there are a couple of considerations. First, the Overall Ratio in first we like to see in the range of 10.x-11.x so that you will have good acceleration from a launch. When the Overall Ratio gets up to 13.x, you may likely feel the car is overgeared - especially if you have a big block.
To understand the difference in gearing a little better, put it in terms of torque multiplication. Let's say you have an engine putting out 400HP and 400LBFT over the power band. Multiply the torque by the gear ratio, and that is the output torque generated out of the transmission (example: 400 LBFT x 3.37 = 1348 LBFT torque in first gear with the RS400/500; or 400 LBFT x 2.80 = 1120 LBFT with the RS600). That's torque gain is great from the point that you can bring your car into motion quick. The downside is that your wheel rotational speed for any given engine rpm will be slower with the numerically higher gear (ex, 3.37) than with the numerically lower (ex 2.80) first gear. Also, because of the law of physics that energy is neither lost nor gained, the HP at the output of the transmission is inverse multiplication of the HP at the input ... meaning that HP in first gear is 400 HP / 3.37 = 119 HP for the RS400/500, and 400 HP / 2.80 = 143 HP for the RS600. Now, understand that the RS400/500 does not use more power than the RS600 in first gear. But simply it makes more torque, but equally less horsepower.
Gear multiplication occurs once again at the differential, with the main difference being that the diff affects ALL gears. The 3.73 is perhaps the most popular GM performance gear because it offers considerably more torque multiplication across all gears than say 3.36. So the 3.73 happens to be what I have found is on the end of the scale for pairing with the RS400/500 and a big block or hot small block. So, 3.9 and numerically higher we generally pair with the RS600 to prevent over-gearing in first.
Now, you have to put this into context as to your engine's output at a given rpm. For the case of the Duntov cam'd small block, that engine doesn't make a lot of bottom end torque, but likes to rev and make HP on the top end. So, that engine can benefit from the additional torque multiplication to get the car motivating without having to slip the clutch excessively. Combine that with the higher rpm redline to make a really fun blast from first gear. For the case of a low end (rpm) torque monster big block, the numerically high first gear of the RS400/500 coupled with lots of engine torque means there will be a whole lot of torque at low rpms, and the consequence may be excessive wheel spin right from the start.
Looking at real world examples is another good point of reference. All Mustang GT w/5-speed cars since the 90s through 2010 run 3.3 first gear ratios. And there are a lot of fast (10.xx sec 1/4 mile) Mustangs running the 3.3 first gear ratio.
Rolling all of the above into consideration, my general guideline for muscle cars running 25-27inch tires is this:
Engines up to 500 torque and 500 HP:
diff ratio of 3.08-3.73 => use RS400/500
diff ratio of 3.9 & up => use RS600
Engines up to 600 torque and 600 HP:
diff ratio of 3.36-4.1 => use RS600
We always discuss these points with the owner/builder during the quote, and any questions or special considerations (large tires, special purpose apps, etc) can be reviewed.
Hope this helps you all to understand the impact of gear multiplication and selection.
Shafi Keisler
01-18-2011, 12:15 AM
Thanks Shafi, great delivery of information. Your time is much appreciated.
| Thread Tools |
| Display Modes |
Linear Mode
