Old 01-25-2006, 09:01 PM
x-tream x-tream is offline
Default Turbo and supercharger question.
This is a crazy question, that some of us came up with sitting around the shop tonight. What would happen, or is it possible, to hook the outlet from the supercharger to the inlet of the Turbo and then into the motor??? Just something to think about!!
Old 01-25-2006, 10:45 PM
mazspeed's Avatar
mazspeed mazspeed is offline
Too much plumbing, incressed lag. How would you fuel it?
Old 01-25-2006, 10:55 PM
ilovefirstgens's Avatar
ilovefirstgens ilovefirstgens is offline
oh i was just about to say it was a clusterfu**... but it sounds better the way you put it.
Brian
'68 camaro
Old 01-26-2006, 12:30 AM
ArisESQ ArisESQ is offline
ive actually seen a turbo feeding into a roots type blower before.... as well as an older car that was featured in popular hot rodding a while ago that had 2 roots type blowers and twin turbos. i dont really think the gains you would see are worth the work necessary to make it run well, but its a pretty cool idea.
and i THINK that some firetrucks have something like that...
Old 01-26-2006, 01:00 AM
pist0lpete pist0lpete is offline
I believe the old 2-stroke Detroit Diesel's have a similar setup.
Old 01-26-2006, 01:31 AM
mazspeed's Avatar
The only advantage I could see is cooler air spooling up the turbo. I'm not a brainiac so I don't know. Sounds lke something a bunch of drunkin gear heads would discuss at the local watering hole. heheh
Old 01-26-2006, 05:09 AM
Speedster's Avatar
Speedster Speedster is offline
More shafts, more belts, more mass, more plumbing = more parasitic loss, lowered efficiency. Pump gas can only handle so much and you can go beyond that with any single form of forced induction.
-Bruce
Project "Freebird"
Dyno Video
http://www.nelsonracingengines.com/...lownbbchigh.wmv
Project Rides:
1968 Firebird - Blown 540
1987 Blazer 4x4 - Blown 355
2007 Magnum
2010 Camaro SS - LSX Twin Turbo
Old 01-26-2006, 12:45 PM
65BelvedereII 65BelvedereII is offline
Kinda along the same line, but Volkswagen is experimenting with a supercharger/turbo setup for the new Jetta's. The supercharger works up to like 3000 rpm and then it switches to the turbo. The supercharger will have a clutch like an A/C on it.
Old 02-24-2006, 09:17 AM
Bamakx Bamakx is offline
No reason to do this on a gas engine. This is done on Detroit diesels but diesels do not care how much you force feed them, the more the better. What you have on the Detroit is the turbos force feed the roots type blower.
Old 02-24-2006, 06:05 PM
JamesJ JamesJ is offline
This is what happens, I think there set up is turbos feeding superchargers.
Here
James J.
