Old 02-01-2011, 09:04 AM
JayR JayR is offline
Lateral-G Supporting Vendor
They appear to be awfully wide which will make it difficult to put in any of our cars and look halfway decent. The hot ticket for IRS that can be narrowed is the Mustang Cobra from the previous bodystyle.
Old 02-01-2011, 09:47 AM
Sieg's Avatar
Sieg Sieg is offline
If the dimensions aren't restrictive it appears it wouldn't be overly complex to fab mounts. Just looking forward and thinking out loud.
Old 02-01-2011, 10:10 AM
holschen's Avatar
holschen holschen is offline
Default i´m trying this at the moment
but it´s a very very tight fit and my camaro is widened about 2" on both sides and runnin 12" 325x25/20" c5 wheels with spacers
camaro69-l92+6l80e-
speedtech(LCA)-ats Street-Comp AFX-unisteer r&p-VariShock
camaro 5gen rear
Hydratech Brake Booster
movit brakes 380mm 6piston front- brembo 465mm 4piston rear
275/30-19 front-325/25-20 rear
19x9f 20x12r cray scorpions
Old 02-01-2011, 10:13 AM
Sieg's Avatar
Pictures please! I knew someone would be on it!
Old 02-01-2011, 11:48 AM
Sandbagger's Avatar
Sandbagger Sandbagger is offline
Originally Posted by ratman67 View Post
who makes that rear assm. or what is it out of?
top secret ,
Yes Im being sarcastic , see first post genius
Old 02-01-2011, 02:17 PM
Sieg's Avatar
It's from the new Hot Wheels Camaro.
Old 02-01-2011, 02:47 PM
mexMan's Avatar
mexMan mexMan is offline
Looks like you're talking about kicking the whole rear frame the hell out of the car, that only to fit that thing, and it's not the lighterst you'de get, I'd rather use a 5 link (and I'm not really fan of it either) that THAT IRS setup, unless you take out the rear frame rails and adapt the setup to them, and in the process make it lighter.
''Every car has a great quality, is not the hands that build it, is the dedication behind it.''
Old 02-01-2011, 08:07 PM
kyle_newman's Avatar
kyle_newman kyle_newman is offline
we havent looked into the camaro iRS but we are in the process of shoehorning C-4 in the bak of this 68.
the fab work in the rear is done, we were able to keep the C-4 in its full width (did not have to narrow) but that is only because the owner is fine with a new style wheel (allot of back spacing).
Kyle Newman
Fabricator @ Newman Car Creations
55 Chevy Newman Car Creations chassis C4 front and independent rear, LS3 376/480, T56
57 Chevy wagon Newman Car Creations chassis, C4 front and independent rear, LT1, T56
www.newmancarcreations.com
Old 02-02-2011, 01:31 PM
ProTouring442's Avatar
Anyone know the hub to hub width?
Shiny Side Up!
Bill
Never met a man with real talent who felt the need to deride the efforts of other.
Old 02-02-2011, 06:32 PM
Sandbagger's Avatar
What year is it and is it a 36 or a 44 ?
How much HP are you puttin to it ? Not to scare you , guys that run sticky slicks, with 11 wheels tend to be hard on wheel bearings . Its a yearly thing with a few AX guys .
I bet you know about that ...
Nice build , would like to see more .
I think 84-95 was one width 96 up was a little wider .
