Old 02-06-2011, 08:49 PM
Not sure it will be enough. There is a special tool for measuring the proper depth. I like to do things once if possible. A local machine shop better have one.
Doing things once is great.. if you can pull it off
So... we've been thinking on this all day... and one other thing that we changed when putting it back together was a higher volume oil pump. We put a Melling 10555 pump in place of the previous OEM replacement M-55 pump. This constitutes a 25% increase over OEM.
Could be the culprit, or at least contributory?
Old 02-06-2011, 08:57 PM
That certainly may have accelerated the failure. It would've died either way. Just a few miles down the road. Set it back up right and you should be good to go until you put in your LSX.
One other thing that can cause the gear failure is cam walk. Is there a cam button?
Old 02-06-2011, 09:07 PM
Ha, I was spending quite a bit of time on LS1tech for a bit there, but now since getting this motor back together and driving a bit, I really love this thing for what it is. Modern tech is great and all, but old school original is..... well, there's just something about it.
And yes there is a cam button in it.
Old 02-06-2011, 09:10 PM
Just making sure Rich didn't forget a piece.
It's in there, use it up first.
Old 02-06-2011, 09:30 PM
Dave -- couple of things.
Noticed the o'rings on the distributor.... hope your block was machined accordingly. The block should have been machined with chamfered edges on it to accept the o'ringed distributor. They are used to RAISE oil pressure...
Todd is right on about the cam -- and needing to double check with the manufacturer about what style billet cam they're putting out. As he pointed out - some are using a pressed on distributor drive gear so that running a "normal" distributor gear is possible for street engines.
There is another solution to running a bronze gear... COMP CAMS offers a synthetic carbon poly distributor gear for around $100. It's stronger than the bronze gear and if you need to run one - then this carbon poly gear will supposedly give you better life in a street roller motor. Supposedly they show NO WEAR. I say supposedly because I've never run one personally. I run the pressed on drive gear roller cams. I just don't need more BS to deal with such as inspecting my distributor gears. I have to disassemble half my air valves and my fuel system etc to get to my distributor! No thanks.
You also DO NOT want to use synthetic oil for break in of a new distributor gear -- they don't have the heavy metals used to protect engine parts like this. You need oil with the zinc etc in it.
Old 02-06-2011, 09:41 PM
Dave --
Forgot to say -- MOST aftermarket blocks are chamfered and then you have to use the o rings on the distributor - but if your block is not chamfered - you take the chance of cutting the rings and they end up in the oil pan... We don't need no stinking parts in our pans!! LOL
I run a Dart Little M block... so have 'run into' this issue.
Old 02-07-2011, 07:52 AM
torino420's Avatar
torino420 torino420 is offline
another gear option that I have been researching since I currently run a bronze gear is Lunatis' "Everwear" gear. Looks like a good option as well as Comps poly gear.
http://www.lunatipower.com/ProductGr...?id=243&cid=43
69 Torino GT Formal Roof
420" Windsor TKO600
