Old 02-06-2011, 09:09 PM
61ragtop 61ragtop is offline
What front clip are you using? Also what are you planning for all the other mods and drivetrain?
Awesome work cant wait to see it all done!!
Old 02-06-2011, 09:30 PM
LILBuzzy's Avatar
LILBuzzy LILBuzzy is offline
Morrison GT IFS, 3 link rear based on stock set up. Nine inch was modified for drag racing but I am going with a watts link now. Already has coil overs and adjustability built in (it was so slick last century ) . IE two piece drive shaft. I trying to con Blake from Speedtech into making some bars for the rear, but I am going to get the front where I want it first. 14 inch wilwoods on the front. Back will most likely match the front. Undecided on 18's, 19's or staggered 18's and 19's. Minitub the rear, and a custom fuel tank. Fuel injected 409 of some sort for power, and an RS 600 from Keisler. Keeping most of the cage and the rest of the interior is a mystery. Just want to get it rolling. Here are a couple of rear susupension shots.
Old 02-06-2011, 10:21 PM
Sounds cool!!!! I am calling Blake tomorrow about sway bars for my '61. I would personally go 19 up front and 20 in the rear, I have 18 and 20 stagger and find the 18's too small for the larger wheel well on the fulsize cars. Just a personal opinion though I thinkit will look killer regardless of wheel size. Keep it up and I will be following this build. Keep the updates and specs comin!!!!!
Old 02-10-2011, 08:46 PM
LILBuzzy's Avatar
got almost all things welded tonight. still gotta mount frame horns though.
more snow...ready for spring
Old 02-13-2011, 04:44 AM
R.A.D's Avatar
R.A.D R.A.D is offline
what are your plans for the mid section of the frame?
Old 02-13-2011, 08:15 AM
LILBuzzy's Avatar
Some sort of through exhaust. Might need to remake the trans crossmember. Trim the center box, and two piece IE driveshaft. havent got there yet, but will post when I do.
Richie
Old 02-26-2011, 09:41 PM
LILBuzzy's Avatar
Default woo hoo bumpers fit
