Old 02-08-2011, 08:57 PM
Roadster Shop's Avatar
Supporting Vendor
RoadsterShop.com
And here is a custom 1970 Challenger Chassis being built with our Fast Track IFS. This is the same type of chassis will be under the 2011 Good Guys Give Away Challenger.
The chassis is mocked up at ride height and tacked together on a flat frame table. From here it will go into a fixtured jig for final welding in order to keep the chassis squared and true.
All bends are fabricated so there are no wrinkled areas that you would get from bending square tube.
Low profile frame rails and center crossmember so a 3" drop can be built into the floor in order to retain headroom.
www.roadstershop.com
