Old 02-16-2011, 05:55 PM
Originally Posted by ironworks View Post
Just my Giant loud opinion but I think It would look better above the axle housing. Bring the exhaust above the half shafts and together above the quick change cover.
Plus it won't hang so low.
Okay -- I can use some 4" thick body mount biscuits to get the room for that design idea...
There is no way to run exhaust on top the rear end.
Old 02-16-2011, 06:07 PM
ironworks's Avatar
Sure there is. Just route it above the half inboard of the shock and close to the disc brake rotor. Then the half shaft will never hit the exhaust.
Rodger
Old 02-16-2011, 06:15 PM
Rodger
Okay - that gets TWO of the three pipes routed....
Old 02-16-2011, 06:36 PM
96z28ss's Avatar
96z28ss 96z28ss is offline
well are you going to do a Single muffler design with three pipes coming out of it or are you going to run dual ehaust into a custom made tip that has the Ferrari 3 pipe look. One is alot easier than the other.
I'm with Rodger there is plenty of room. More room than most cars.
Your pretty good at the CAD stuff. Everyone is doing it now.
1969 Camaro LS2/T56 D1SC
www.automotivedesigneng.com
Old 02-16-2011, 09:14 PM
I posted that CAD up before I could give you credit for it! Sorry!
Too easy to hit "send".
I'll run dual exhaust and this design as a 'tip'.
Old 02-16-2011, 09:22 PM
96z28ss's Avatar
I wasn't looking for credit, I was trying to make it look like you did it, but you had to go and ruin that, huh!
The center pipe does get cut out into the 2 outside pipes. Not sure if it will affect the sound any. It will atleast have exhaust flowing out of the 3 pipes. Wouldn't want it to be just cosmetic.
Old 02-16-2011, 06:57 PM
ironworks's Avatar
Well there is only 2 pipes from the engine so the other is really just an exhaust tip. Unless the 3rd pipe connects to your butthole.
Old 02-16-2011, 08:45 PM
toddshotrods's Avatar
toddshotrods toddshotrods is offline
Just make it a little resonator.
Todd Perkins Design
Old 02-16-2011, 09:17 PM
Todd ---
I like your little "resonator" idea... it would probably take some mock up to get the sound right??
Have to thank both you and Bob for your work! Super kool stuff!
Old 02-16-2011, 09:24 PM
No problem, I really couldn't resist doing it. I cheated and just Photoshopped the CAD rendering though.
...it would probably take some mock up to get the sound right??...
That's the fun part.
Todd Perkins Design
