Old 02-27-2011, 07:20 AM
Sieg's Avatar
Sieg Sieg is offline
Welcome Tom!
I have not seen any of the "top" Camaro parts vendors promoting fiberglass springs and I haven't seen any project cars using them. The trend is coil over 4-link or torque arm rear suspension, which would be my recommendation if you want to take on the big boys.
I considered them 10 years ago, but ended up with Global West steel leaf @ 175 lb. I went 2" lower and added 1" blocks and it's still a little high for my liking. These cars vary a little so don't rely on my numbers. FWIW - My future plans include SpeedTech's torque arm rear suspension.
Old 02-27-2011, 04:43 PM
T-T T-T is offline
Thanks for response.
I know, -it's certainly not easy to play with the big guys (or girl).... but why not - I know that the road is long and most of the road is uphill, but the big guys also began their dreams as little boys .....
-- Okay - You're probably right, that it would be more up to date with a 4-link system from one of the major vendors, - but there is just this huge problem here in Denmark. - It will still be a legal streetcar with license plates on, - and if (read when) I get tackled by police (the state), they will look at my "old" 1969 Camaro like a brand new car and therefore collect a huge amount of tax as if it were a brand new car - we're talking about plus 8-9000 dollars. -Yes!
Therefore we have to rebuild cautiously, with only small improvements in our old cars.
...and therefore a set of leaf springs of composite is very interesting -if I can reduce weight by 30-35 pounds per leafspring (60-65 pounds waauuw!!), it can not be all wrong.
I´m looking forward to here some more response - Thanks
Old 02-27-2011, 07:01 PM
Sieg's Avatar
Check this rear system: https://lateral-g.net/forums/show...&postcount=161
Dollar for dollar it's one of the better options and appears to be a relatively simple install. Certainly not a cheap as a simple leaf spring change though, but if you want to play with the big boys I don't think leaf springs are the answer. Don't know how the state regs would apply to this kit.
Old 02-28-2011, 09:17 AM
JKnight JKnight is offline
I run 220 lb/sq in. Hyperco composite leafs on my car with a Fays2 Watt's link. I can tell you that the ride is great due to the lower unsprung weight and it handles really well. I haven't done any competitions so I have no numbers or rankings in events to back it up, but for less than $1,500 I feel I have a very competent rear suspension. I believe I will need to add a sway bar or more front tire to improve balance at some point, but for an 90% street car it's not really necessary. I would have preferred the adjustability of a 4-link, but given my budget it just wasn't in the cards.
I would think one of the limitations, downsides, for any fiberglass spring is going to be with axle wrap/wheel hop. This has not been an issue for me thus far, but I'm only running 425-450 hp and have a heavy 9" rear end in the back.
Old 02-28-2011, 10:03 AM
T-T T-T is offline
Originally Posted by JKnight View Post
I run 220 lb/sq in.
Hi JKnight. -Thanks for responding-
- You got the 220lb??.. isn´t that too hard, -when i look in the Classic Industries catalog they are talking 125(mono) to 143 lbs(multi)??
- Yours 425-450 is almost the same as i´m planing.
The guy at VBP ask me - whether they should be prepared for Calvert Racing Caltrax bars - maybe that´s the way to do it?!
Tom
Old 02-28-2011, 10:54 AM
You have to keep in mind the end user for a spring from Classic industries. That guy is going for a restoration, not building a Camaro to handle on the street or track.
I don't believe mine are too stiff at all. In fact, I would have no problems going with 250 lbs or maybe even higher. Paired with a good shock, there is no rough ride associated with a spring that strong. The reduced unsprung weight helps the ride quality quite a bit.
Old 03-01-2011, 11:33 AM
T-T T-T is offline
Okay - many thanks JKnight.
and next .............?????
Come on guys..... are you serious now
- there must be several Camarosss out there who have mounted a pair of fiberglass leafsprings - otherwise the company must be close to shutting down the fabrication.
