Old 02-27-2011, 08:45 PM
Pasquale Pasquale is offline
Originally Posted by nvr2fst View Post
RPM transmissions IMO builds the most stout C5/C6 trans/diff packages for heavy hp and torque. The IRS most likely will cost u way, way more than other rear end set ups if you plan on mimicing the vette set up. Jakes Rod shop gave me some info awhile back ago about a shop that is building IRS rears the more conventional way. I believe using a 9" ford housing, but could be wrong. Check with JRS.
Alright I'll give them a call tomorrow. They look like they have a nice sub frame also.
Do you guys know the why people install an IRS. Do most people use an IRS for good street handling or do they install it more for show?
Old 02-28-2011, 10:30 AM
BMR Tech's Avatar
BMR Tech BMR Tech is offline
On a smooth road course most will agree that there is no real advantage to IRS. On the street with a properly setup IRS you can have an advantage mainly due to the road inconsistencies and the IRS's ability to compensate with each wheel "independently". They are much more difficult to make work with a high horsepower car however, not to mention much more expensive.
A properly setup solid axle is generally very difficult to beat both in cost effectiveness and simplicity. There are many options out there but it's hard to beat our Torque arm Suspension when it comes to ease of installation, included options, and overall usability. Because of the centrally located main link, a torque arm works similarly to a 3 link design when it comes to bind-free axle articulation. The torque arm acts like a ladder bar in preventing axle counter-rotation and maximizing weight transfer except without all of the negatives associated with ladder bars. Our kit is 100% bolt in wether you are using a 10 bolt, 12 bolt, or Ford 9", no welding or fabrication required.
If you have any questions, please feel free to contact any of our knowledgeable sales staff at 813-986-9302.
Brett
WWW.BMRSUSPENSION.COM
