Old 02-09-2011, 11:05 AM
BMR Tech's Avatar
BMR Tech BMR Tech is offline
Talking BMR Launches New Product - Torque Arm Suspension for 70-73 Camaro/Firebird
BMR Suspension
Torque Arm Suspension for 1970-1973 F-Body
Gain superior handling and greater adjustability in your 70-73 Camaro/Firebird with a Torque Arm Suspension from BMR Suspension. This complete kit comes with an adjustable torque arm, Watts Link, torque arm cross-member, coil-over conversion cross-member, lower control arms, and all necessary mounting hardware. The torque arm is equipped with a Delrin-bushed, telescoping front mount for bind-free axle articulation and a pinion-angle adjustable rear mount. The Watts link centers the rear axle housing even if the suspension is fully extended or compressed. The BMR Torque Arm Suspension (TAS004, TAS005, TAS006) is a true bolt-in kit that can be installed without cutting or welding the floor or frame. The suspension can be unbolted and the car can easily be returned to stock if desired. Applications for 10 bolt, 12 bolt, and Ford 9”. The Ford 9” version includes a new Strange rear axle housing. Coilover shocks sold separately. Available in black hammertone or red powdercoat.
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email [email protected], or contact them at BMR Suspension, 12581 US Highway 301 North, Thonotosassa, FL 33592, 813-986-9302, Fax: 813-986-8055.
Brett
WWW.BMRSUSPENSION.COM
Old 02-09-2011, 03:31 PM
coolwelder62's Avatar
That's a real nice lookin product. Scott
Old 02-10-2011, 03:25 AM
ProTouring442's Avatar
Sweet... now we need one for the A-body guys.
Oh, and it will need to fit a Ford 9"
Shiny Side Up!
Bill
You ever wonder what medieval cook looked at the guts of a pig and thought, "I bet if you washed out that poop tube, you could stuff it with meat and eat it."
Old 02-10-2011, 06:21 AM
BMR Tech's Avatar
Shiny Side Up!
Bill
Working on the Nova's now, maybe A-Body will be next if we keep getting requests for them!
Brett
Old 02-11-2011, 06:17 PM
jake72ss jake72ss is offline
Default A body
I second that, if you dont I might build my own.
Old 02-17-2011, 08:34 PM
manny z manny z is offline
Default torque arms-watts link
I own a 68 dodge charger. It is in the capeable hands of GEARHEAD GARAGE.
Now I would be more then capable of making a similar rear suspension for my car, if I was not deployed. My quesion is this, and i am sure fellow mopar owners would agree. Would you be interested in making this type of rear set-up for a B body mopar?
Old 02-21-2011, 01:44 PM
BMR Tech's Avatar
Interested, yes, but.....we generally plan our R&D schedule off of customer demand. As it stands at the moment the B-body is not an application we have received much interest in. On top of that, we are probably 1.5-2 years booked on new product development as it is so.....
We have already sold a bunch of kits to people retro-fitting them into other chassis. I know one was going into a Studebaker, one a 2nd gen Nova, and another for a pickup truck. You would have to use the 9" version for this to happen in a Mopar but we can sell the rear in whatever width you prefer, make control arms extra long, cut to fit, and build the torque arm length to order if desired. These are the only alterations we will do but make the kit somewhat adaptable. You would still have to adapt the shock crossmember and torque arm crossmember to your floor which may or may not be a complicated process depending on your fabrication abilities and floorpan/frame restrictions...
Brett
Old 02-24-2011, 08:07 PM
Default rear suspension.
In that case, when the car is to the point of getting the rear done on it, i will be getting in contact with you with all the specs. The rear shock member is no problem. thanks.
Old 02-28-2011, 11:54 AM
drednot's Avatar
drednot drednot is offline
I am anxiously waiting on the nova version! A 1974 nova to be exact. I like the bmr versus the speedtech because it looks like an easier install for people like me.
Old 02-28-2011, 02:14 PM
drednot's Avatar
To Brett at BMR-What is the main difference in the 12 bolt versions and the 10 bolt versions? I have a 10 bolt and plan on upgrading to a 12 bolt later on. Can I swap (when yall get it set up for Novas) your TA from a 10 to a 12 bolt easily?
