Old 03-12-2011, 01:30 AM
CrossRamRich's Avatar
CrossRamRich CrossRamRich is offline
Gettin ready for Marina Autocross on sunday. Badmotorfinger needed a little attention after the big road trip to RTTC. Plugs, valve adjustment, etc. Stout performer!!!!
Rich Bermea
Road Touring Customs
Gilroy, CA
Old 03-12-2011, 07:33 AM
Rich -- THEN QUIT POSTING AND GET YOUR AZZ BUSY BOY!
One of these days when I get rich like Charley and Dave - I'm gonna get me one of them there ride along mech-a-necks!
Old 03-12-2011, 07:45 AM
It's Mike Honcho. Don't tell anybody but he "Spread his but cheeks for Playgirl magazine"
Rich, did you find any loose valves? How is the gear doing?
Old 03-12-2011, 07:50 AM
Shouldn't you be at an open house or something?
Old 03-12-2011, 08:04 AM
I don't do open houses.
Old 03-12-2011, 11:26 AM
Valves were consistently off by about .003 Rich said.
Distributor gear is in perfect shape. Some more gear material from the previous gear was on the magnetic plug and a little in the oil filter.
Oil was black and a little low (yes we are working on a DIPSTICK solution).
Timing was down to 30* which was a little worrisome. But Rich discovered we were still using a cheapy distributor hold down that was likely the culprit. Replaced with better MSD hold down.
Replaced old plugs (should have down before probably) with new NGK 7938's.
Old plugs showed a little detonation so timing was set to 36* and Rich threw some Lucas octane boost in the fuel cell so we will see how she runs tmrw at Marina.
EDIT: Rich, I guess we are pretty much on the same page!
Old 03-12-2011, 11:20 AM
Thats beautiful!!!
Yes all the valves were around .002 to .003 off thier cold adjustment. .015 intake .017 exhaust. Gear is beautiful put a MSD holdown on, lost 6 degrees with the cheap one. Had a bent cheap fuel pump block off, caused leak at RTTC. Distributor cap, center electrode broken, replaced. New plugs, NGK, gapped at .045. Oil was DONE. Shifter still bein funky, workin on that more today and fixing a collecter gasket. Trying out Lucas octane boost, seems to be working. Now try and catch us!!! We need a good radiator catch can, any suggestions?
Rich Bermea
Gilroy, CA
Old 03-12-2011, 11:40 AM
Sieg's Avatar
Sieg Sieg is offline
Rich,
Might give Kemco 130 a try too: http://www.kemcooil.com/products.php?cId=4
I've had good luck with it in my bikes. Leaded with a nice racey aroma.
Old 03-12-2011, 10:45 PM
Rich,
Wow! Thanks for the tip. That stuff is the real deal. TEL, main ingredient, that'll work.
Rich Bermea
Gilroy, CA
Old 03-12-2011, 11:48 PM
How much capacity would you prefer, Boss? I can source this.
