Old 04-03-2011, 03:51 PM
boostin05blacks boostin05blacks is offline
Originally Posted by johnnymac46 View Post
I'll be home in two weeks, the car is prepped and ready for the clip I'll try to take a lot of pics of it going in. I can't wait to get it back on the ground.
Does anyone have any recommendations on where to find a LS/T56 dropout?
I've been looking at the LSX 376 and 454 I'm not sure which direction to go yet.
I'm open to suggestions
They are very different motors. I just bought the lsx454 and it's expensive. But when it's all said and done I'm hoping it all worth it. There is a dealership I talked to in my search that has the Lsx 376 for 4500 shipped if you do wanna go that option. If you want the 454 let me know I know where to get it around 9400..good luck with whatever you choose.
Old 04-03-2011, 05:18 PM
johnnymac46's Avatar
johnnymac46 johnnymac46 is offline
I've been following you build pretty closely it's coming along nicely.
I'm a complete newb when it comes to LS engines I'm seriously considering a dropout package but I really don't know Which LS to go with.
Due to my short 23 years of knowledge gathering time I've had on this earth I have a limited amount knowledge of engines except for the standard sbc 350.
I've done a lot of reading on lat-g and protouring but I'm still learning any information on an engine I should or should t go with would be helpful
Old 04-04-2011, 06:33 AM
Thank you. Im only 25 and dont know to much either to be honest. I can tell you this. If you want to go with an lsx 454 youll have somewhere around 500-600 wheel depending on how you set it up, you can make more than 600 but youll be getting into upgrading to a turbo/charger/nos + internals. If you are looking into this motor be prepared to put out around 13-18k depending on your set up..used parts/new, gm parts/aftermarket..ect. There is so many options. I thought very hard about going with a full gto or vette drop out. Pick a part sells them on here for very reasonable prices. You can get a full ls7 w/o tranny for around 10-13k...thats with almost everything you need accesories, ecu, wiring, sensors, brackets, pedal, ect. Or you can go with a complete mast lsx for 13-17k power ranges adjust as you spend more. Just food for thought. The main reason I went with the motor I did is because I like the gm 2 year warrenty and that its all gm. Its going to cost me more in the long run but its the motor that ive dreamt about, Id rather do it once the way I want then do it twice fixing it to my liking due to money. Read my thread there is some great info and knowledge on all of this. Good luck with what ever you choose. Ill be watching.
Old 04-16-2011, 05:39 PM
Im finally home again, I just ordered full length floor boards, and a DSE firewall fill plate.
Tomorrow is the big day, I get to see my AME rearend for the first time tomorrow. I'll post some pics tomorrow of the rearend and hopefully get it installed before my shoulder surgery in 2 weeks.
I still havent decided on a motor, but I will have plenty of time to figure that out while my shoulder is in a sling.
Old 04-20-2011, 04:42 PM
Im finding the more I dig into my car the more cancer I find, and the more I realize I need to buy a plasma cutter.
I havent gotten the rear clip installed yet, Im waiting on some more parts...
One question, with the DSE firewall fill plate, is the general consensous to cut the firewall out or weld it in over the top?
- I was going to cut out the old firewall until I saw the rounded edges, and it looks like its designed to weld over the top of the existing firewall.
again any help is greatly appreciated, Im gonna cut and install in a couple of days unless someone can convince me otherwise.
I'm having shoulder surgery in 7 days and wont exactly be able to cut, hammer and weld after that...Im not sure how I'll spend my time.... Ill probably install my driver seat and make lots of engine noises during my recovery
Old 04-20-2011, 07:18 PM
MODO Innovations's Avatar
I installed my DSE firewall fill plate over the top of the existing firewall. You will need to trim the flange off of your a/c hole in the existing firewall so that it will fit flush. Then again, if the firewall is rusted badly you could trim it out leaving about an inch or so below the seam at the top and also leaving that much on the rest of the profile fill plate. This will leave a flange to weld the new fill plate to. In my opinion, I think it depends on the shape that the firewall is in.
Either way is fine.
Be sure to prime the inside of the fill plate and the firewall that will be covered by the fill plate. Weld primer works really well for this.
If you look at DSE's site on their project page you can see how they walk around it when welding to keep it from warping. Be sure to grind the welds the same way, walk around it and take your time.
Good luck with the shoulder surgery.
Shannon
Modo Innovations
940-391-9002
Old 04-20-2011, 08:36 PM
Of all the DSE firewall installs I've seen in the various threads here and elsewhere I felt Jay's approach was one of the best. His thread can be seen https://lateral-g.net/forums/showthread.php4?t=9421 but it looks like some of his older pics aren't showing up any longer.
I think plenty of installs are done on top of the original sheetmetal and given the rolled edge I think it would work ok. I was just concerned about the risk of noise/vibration from the gap between the panels but that could be mitigated with some seam sealer probably.
Or you just cut most of it out like Jay did and not worry about it. In addition, he drilled the spot welds and completely removed that outermost layer of sheetmetal. The added benefit there is your fender mount isn't pushed out any like it would be if you just added another layer.
I found these in his other sites gallery
John
'71 Nova (Build thread)
FFR Roadster
