Old 04-14-2011, 06:27 PM
67Rally's Avatar
67Rally 67Rally is offline
Bite the bullet and get Speed Tech's Track Day package.
And a carbon drive shaft since the torque arm will protect it from road debrie.
Heheh. Let's pretend I didn't have $10k to put towards the suspension for a moment...
Old 04-14-2011, 10:19 PM
Sieg's Avatar
Sieg Sieg is offline
It's not the cost of their suspension that's holding me back..............it's the brakes!
Be realistic with your net out of pocket estimates when factoring the front option. When it's all said and done how much more would you be out of pocket if you went with their front subframe setup? And which option will add more performance and resale value to the car?
Old 04-15-2011, 05:04 AM
67Rally's Avatar
$4900 list for their front subframe setup.
I already have brand new steering box, rag joint, pitman arm, idler arm, center link, inner and outer tierod ends, heavy duty tierod sleeves, and front sway bar.
So I would be looking at the cost of UCA/LCA plus shocks and springs, or plus coilovers. Somewhere in the $1500-$2000 range.
I can't justify the extra $2900-3400 on a new subframe right now.
Old 04-15-2011, 06:05 AM
Sieg's Avatar
In that case, the Speed Tech arms and probably the Ride Tech coilovers. The adjustability of coilovers vs. traditional coil springs is a plus.
Old 04-15-2011, 06:09 AM
DOOM's Avatar
DOOM DOOM is offline
SPEED TECH hands down!!
Mario
USCOLLISION
