Old 04-17-2011, 09:03 AM
It cuts fine with a cut off wheel.... just yard the cable out first... if you can't do that just be real careful. You only have to cut one coil.... if it's like the ones I've done it's a wire wound sleave covered in vinyl. Remove the covering so you can see the wire and just buzz thru it.
Old 04-17-2011, 09:20 AM
wmhjr wmhjr is offline
Thanks Greg. That's what I figured but thought I'd ask any more experienced gurus first. I will have the cable out. I'm going to run the sleeves and mount them prior to feeding the cable through.
Old 04-17-2011, 10:38 AM
Welcome buddy!
