Old 04-04-2011, 03:14 PM
Default Anybody running a T-56 Magnum behind a big block?
Looks like price of the magnum has came down some since it first came out, e.g. ~2800 now. That isn't too far from the price of a good 4l80e so I've been thinking .
Just curious if anybody has experience with the Magnum behind a healthy big block. The 700 ft/lb rating provides some comfort. Is Quicktime the go-to bellhousing for this setup?
John
'71 Nova (Build thread)
FFR Roadster
Old 04-05-2011, 10:15 AM
Nick.V70's Avatar
Nick.V70 Nick.V70 is offline
I too am in the market of a tranny and was going to run a TKO600 w/BBC but may change over to a LS later and wanting to know about a T-56 Mag. up against a BBC for now so I don't waste money on another tranny.
Bump for you and I looking for suggestions....
Nick's 1970 Chevelle project - '70 SBC 383 Stroker - Rushforth Rated X wheels - 14" Wilwood - Anvil Carbon Fiber hood/deck lid - Fesler billet - Corbeau Sport Seats, and still building....
YouTube & Chevelle pics - Instagram @nick.v70 & @ChevelleFactory
Old 04-05-2011, 02:28 PM
Yeah around here it is LS or go home . No love for the boat anchor big blocks. Well I guess Todd is the exception HA.
With the 700 ft lb rating I think it would be fine except for extreme builds and/or one too many trips to the strip with sticky tires.
I also considered the TKO 600 but the RS600 from Keisler sounds good at the moment. Too early to get much "real world" feedback yet but I like the concept. Good bit more money than the TKO though if you don't already have a bellhousing, etc that you can use.
John
John
FFR Roadster
Old 04-05-2011, 05:32 PM
Nick.V70's Avatar
I hear you. I just heard about the RS600 and thought the same as in giving it some time to see.
Old 04-05-2011, 09:03 PM
John
Somebody has to do it the cool, expensive, hard way.
Old 04-07-2011, 06:37 AM
LarryC5 LarryC5 is offline
BBC71Nova.
I'm in the process of collecting all of the necessary parts for a T56 Mag to a BBC install. Trans arrived a few weeks back along with the Quicktime Bell (will go with hyd throw-out bearing). Bell is a nice piece.
Now just waiting for the new BB540 to be completed by the builder. It does not seem that many have gone with the T56 Mag to BBC combo. Most are LS related installs.
For me, I'm hoping for no major surgery required on this install. So far, it is a coin toss. Will know for sure shortly.....
On the trans crossmember, have you decided on which mfg to use? This is one area I have not yet covered.
Larry
Old 04-10-2011, 07:22 PM
Larry,
This T56 Mag may end up being a pipe dream so no, I haven't gotten far enough to make a decision on the crossmember. The ATS one is nice though from everything I've seen/read. Then there are a few others on the market as well. Keisler's looks nice too.
I think the biggest issue is finding one that has been designed and proven for the BBC and specifically for the factory BB frame mounts that shift the engine to the passenger's side. That's why the OEM TH400 crossmember is offset.
John
FFR Roadster
Old 04-13-2011, 08:01 AM
Nick.V70's Avatar
Originally Posted by LarryC5 View Post
BBC71Nova.
Larry
Larry, what are you putting this combo in? I am liking your direction..
Old 04-17-2011, 10:20 AM
Nor-Cal-Nick,
Putting the trans into a 69 Camaro. The new engine is a Brodix block based 540ci. The six speed swap was not something I planned to do with this particular car (I have a new built 2004R by Calif Perf. Trans) but the Summit discount offered last December certainly enticed me to go this path plus I feel the need to shift gears once again.
Larry
Old 04-17-2011, 11:41 AM
wrighton wrighton is offline
I will also be following this as I have have had a BBC sitting for a long time to go in a 69 and want to go a 6 speed route. I think the ls base engines are bad ass and are proven. but something staying a little old school with the BBC appeals to me. Hope it works out so that we can partake in shifting through 6 gears.
