Old 04-18-2011, 04:07 AM
19,69camaro 19,69camaro is offline
Another option you could look into are the 8.5" 10 bolts I think they started making them in 1971 there are millions of them out there and they are almost as strong as a 12 bolt. Check out this article http://www.chevyhiperformance.com/te...all/index.html
Old 04-19-2011, 09:09 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
That is what I am running in my car. There are different widths on those. I think the one that is the same width as a camaro is from 73-79 Chevy Nova, Oldsmobile Omega, Pontiac Ventura. I think the 2nd gen camaro rears are 1" wider per side. Depending on the wheels you are running, if they are from a late model camaro/vette you can run an impala 12 bolt rear because it is wider than the camaro by I believe 1 3/4" so you don't have to run spacers.
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
Old 04-20-2011, 05:07 PM
BadA** SS's Avatar
BadA** SS BadA** SS is offline
98-02 rear's are junk i blew mine up in my 99 ta and i wasnt even pushin much power to it
2000 SS M6 - traded
-torquer v.2, ls6 intake, headman lt's, SLP lid and bellow, ported ls6 oil pump, ls2 timing chain, true duals with bullet mufflers
1971 SS Camaro
-ls2 403ci (in the works)
1999 trans am
-painted ls6 intake, ceramic pacesetter lt's,SLP lid and bellow, full length true duals with bullet mufflers, Sam Strano lowering kit, ruff racing 278's, strange S60 3:73 gears, Zex 125 shot
Old 04-21-2011, 06:32 AM
Black93GT's Avatar
Black93GT Black93GT is offline
You're right... its junk. Once I saw the post on the '71+ 10 bold info I started pulling the brakes off the '98. good thing i didn't waste time with it.... the gears in the diff were destroyed. Now I just need to find a newer rear.
