Old 04-22-2011, 11:03 AM
JayR JayR is offline
Lateral-G Supporting Vendor
5-5.5" would be ideal for a 9 with a 275mm tire in a stock wheelwell so add at least an inch to that to fit the additional inch of wheel and maybe a hair more to handle some extra tire width and sidewall bulge for the larger tire and the tuck the Ride-Tech will provide. And since these are 45 year old subframe cars made on multiple assembly lines that you're now modifying, it's a good idea to take a few measurements beforehand.
Old 04-27-2011, 03:35 PM
Z06vette's Avatar
Z06vette Z06vette is offline
I have a 19x10 w/275 tire on my 67. I'm about to pull them off to get the car cleaned up to sell, can give you some backspace measurements tomorrow if no one gets back to you before then.
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 04-27-2011, 03:54 PM
astross89 astross89 is offline
Thank you. I have it all worked out, but I still would like to know yours. It looks like I would have to add 1-2 inchs of back spacing on yours because I would need them to tuck. Thanks
Old 05-10-2011, 02:25 PM
ArisESQ ArisESQ is offline
i know that for stock wheel wells, to fit an 18x10 with a 295 you need 5.75 inches back spacing. that's what i have on my car. since then i've mini-tubbed it, and now there is a ton of space between the inside of the wheel and the tub.
if you're mini-tubbed, then you can get away with 5.5 since the wheel tub isnt a limiting factor.
