Old 04-26-2011, 05:29 PM
awake1630 awake1630 is offline
previously i had a muncie m20 with the stock type muncie/turbo 350 crossmember. everything fit well and i had plenty of room with the HEI cap on the motor.
Now with the tko600 and the new crossmember it pulled it down.
I am getting another crossmember hopefully this works and helps the situation.
If not im back to square one.
Old 04-26-2011, 05:35 PM
can some of you guys get pictures of your setups?
I will try and get some pics also.
Old 04-26-2011, 05:38 PM
how much did you have to space yours?
Old 04-26-2011, 10:55 PM
DarkoNova DarkoNova is offline
Banned
I put a kit from Classic Chevy 5 Speed in my 69 Nova. Don't remember the name of it, but it was the full automatic to manual conversion kit. Everything just bolted right up. My big HEI wouldn't fit, but I just bought an MSD distributor instead of adding a spacer.
Old 04-27-2011, 04:08 AM
also has anyone tried running anything other then synchromesh?
I know synchromesh is recommended but when push comes to shove the tko is still a gearbox like a muncie.
So anyone run gear oil with success?
