Old 04-30-2011, 01:35 PM
67ragtp 67ragtp is offline
Thanks Greg - Ill be making up some test cables shortly. Thought I had this nailed down, oh well
Old 04-30-2011, 05:20 PM
If it was easy...... the fat chicks would be doing it.
Old 04-30-2011, 05:45 PM
Ron in SoCal's Avatar
I'm turning you into NOW...
Ron in SoCal
69 Camaro in progress
Old 04-30-2011, 05:48 PM
I would also DOUBLE CHECK that you have 12V + at your lead from the relay...
Sometimes these are 12V- in order to run to another relay.
Old 05-07-2011, 08:01 AM
IT RUNS!! YEE HA!! Not very good, but nice to see good oil pressure/ fuel pressure and hear it come to life. In great backyard mechanic style I hooked up some home depot drain tubing and with a couple of pvc elbows, stuck it to the back of the muffs. It doesn't run very long, wont idle, but I believe the computer/MAF needs the proper parameters. It does sound healthy. Im kinda stuck at this point since I dont have hp tuners and really would bumble my way through the software. Got a leak at the firewall on one of the heater core fitttings so I need to resolve that. I tried the video feature on my camera but its not very good although if you turn up the volume you can hear the magnaflows barking.
Old 05-07-2011, 09:22 AM
DOOM's Avatar
DOOM DOOM is offline
Thats great Rich!!!!!!
Mario
USCOLLISION
Old 05-07-2011, 10:06 AM
bonecrrusher's Avatar
bonecrrusher bonecrrusher is offline
That car looks niceeee!
2005 LeMans Blue Corvette w/ T56 & Z51 & C6Z06 Brakes, Build Thread: https://lateral-g.net/forums/showthread.php4?t=27408
2005 GMC Sierra 2500HD - LLY - Allison
2014 Chevy SS - LS3 / 4 Doors
Old 05-07-2011, 02:20 PM
Congrats Rich! Car looks great...
Ron in SoCal
Old 05-07-2011, 02:57 PM
BritishGreen68 BritishGreen68 is offline
Wow man looks great! What shifter are you using?
Chris
Under construction-British Green 68 Camaro-
Old 05-07-2011, 04:41 PM
Thanks Guys
The shifter is a pro 5.0, I cut the threaded portion off the handle and welded a 3 inch stainless shoulder bolt at the angle I liked.
Thanks again Rich
