Old 04-05-2011, 10:09 AM
s10pro s10pro is offline
Default any one running sumped tank and external pump on ls1
i am doing a ls swap in my 68 camaro, i don't want to spend 1500 for a tank is any one running sumped tank and external walbro or other pump that is not having the fuel slosh prob like what people are having with the sperta tank.
Old 05-12-2011, 08:12 AM
BanditDave BanditDave is offline
On my pro-touring '78 TA I ran a sumped stocker with pre and post pump filter, Vette regulator, and single line to the front. Pump was a Bosch 044...fantastic pump.
Never let the tank get below 1/4 tank I don't think and just drilled a ton of little 1/4 holes in the bottom of the tank before welding on the sump. Worked well for what it was but if you stopped really hard you could hear the pump change sound for a second then recover.
Good luck!
Dave
