Old 05-15-2011, 09:12 AM
The WidowMaker's Avatar
for what application did they recommend the RXT vs the RST?
they said any application where you could smoke the clutch (auto x, road racing, drag racing etc.). from what i have read, the rxt is VERY street friendly.
I have heard that the McLeod TO bearings are not very good--but this is not my strong suit and I'm looking to get a quick education via this thread!
ive heard that as well. but to their defense, i havent heard much good about any t/o bearing.
"The WidowMaker"
Old 06-17-2011, 06:17 PM
BTTBSS BTTBSS is offline
Default Clutch release systems
I just bought the TO bearing and lines from American Powertrain. Bearing looks very similar to the McLeod unit but AP says theirs has larger seals that are supposed to fix the leaks reported on the McLeod unit. I had some questions about the installation and took my TKO-600 by their shop. They put it on a bench and installed the parts. I had a different bearing retainer so they took one off a new trans and I was out the door in under an hour.
Trans goes back in the car this week-end so I can't report on how it all works yet, but they get A+ for customer service.
1996 Impala SS, Red Bow Tie Mod
Old 07-01-2011, 05:58 PM
American Powertrain American Powertrain is offline
Is this Hydraulic throwout bearing week? I also just got one from American Powertrain. Soooo much better and pedal effort is fantastic. I think the master cylinder they use was part of the solution.
http://www.americanpowertrain.com/GM...hydraulic.html
Old 07-01-2011, 08:59 PM
what/whos were you using before? i still havent made up my mind......
"The WidowMaker"
Old 07-02-2011, 09:59 AM
jocko124 jocko124 is offline
Looks like I'm going with the McLeod 1400-30 unit.
Lee
1966 Cutlass
The difference between truth & fiction: fiction has to make sense.
Build Thread:
https://lateral-g.net/forums/showthread.php4?t=31963
Old 07-02-2011, 10:01 AM
Fluid Power's Avatar
Please don't. I had 2 and ended up with a RAM unit. Tons better.
The Mcleod leaked right out of the box....Twice! I will give you the one I just took off if you enjoy that kind of punishment.
Seriously. They are junk.
I used a RAM unit that mounts using the stock bearing retainer. (TKO 600) Straight forward to install. Take a lot of measurements and then shim accordingly.
http://www.ramclutches.com/Products/...se_bearing.htm
Hope this helps. If you have any questions, ask away.
Darren
Old 07-02-2011, 12:13 PM
Darren
Thanks for the heads up Darren. I'll have to do some more research to see if RAM makes them for the Ford T-56 Magnums (vs the GM T-56's). I have the stock GM TO bearing which is supposed to be pretty reliable and is much less expensive than the McLeod---but it doesn't fit.
Lee
1966 Cutlass
Build Thread:
Old 07-04-2011, 11:40 AM
Ron in SoCal's Avatar
A few months ago I picked up Mcleod PN 14-302 for the T56 Magnum. I hope it works better than what you guys have experienced cause pulling the tranny multiple times is no fun!
Ron in SoCal
69 Camaro in progress
Old 07-07-2011, 07:49 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
Darren
Darren, which one of these from RAM did you use? When I clicked on the link, the page has like a million of them.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 07-04-2011, 08:32 PM
I had a McCrap bearing before.
