Old 05-16-2011, 09:38 AM
aussiebj's Avatar
aussiebj aussiebj is offline
Default E36 BMW Street/Track beast part 2
Ok I know its not a camaro or a mustang ..but it will be low have big wheels , flared fenders and shock some people..Oh and have a beast of a ford 302 in it with a 5 speed...here are some pics...started off with a 93 325Is and removed just about everything....
My daily driver and track car
Old 05-16-2011, 09:41 AM
aussiebj's Avatar
I started the task of stripping out the black interior , wiring ,a/c setup and sound proofing .***** theres alot of wiring and soundproofing in theses cars and its heavy..
here is just the rear stereo wiring...*****
Old 05-16-2011, 09:43 AM
aussiebj's Avatar
Here r some pics..The engine and tranny combo removed weighs almost the same as the 302 and T5 going in but the V8 is further back when installed than the big 6 that i removed
Engine and tranny removed
suspension removed
sunroof deleted and lightened
Old 05-16-2011, 09:45 AM
aussiebj's Avatar
To install the roll bar ( that will be removed eventually and a custom cage installed ) I had to weld up the drain holes in the floor first..these will be covered with a better plate once the real roll cage goes in
4 point Autopower roll bar in
Old 05-16-2011, 09:47 AM
aussiebj's Avatar
Who likes wiring ...what I did was start from the fuses to work out what i did not need , and then just followed the wires and removed them ..boy was there some wires in this car...not like wiring up my 69 mustang ...take a look at the pics
And just in case you ever wondered whats under the fuses cover here ya go..
Old 05-16-2011, 09:49 AM
aussiebj's Avatar
Did the front x member reinforcements..to support the torque of the V8
Here is how she sits as of today..
heres the race tires for now eventulyy 315`s will be out back
Old 05-16-2011, 09:51 AM
aussiebj's Avatar
Installed today .....Pss9 coil overs..95 M3 brakes ,spindles and steering rack.. with new lca`s and tie rods... with big turner used front sway bar..
Old 05-16-2011, 09:52 AM
aussiebj's Avatar
fabbed up and installed some Lexan side windows..
Old 05-16-2011, 09:53 AM
aussiebj's Avatar
Here she is ready to go in will she fit...you can see the motor mounts which i put on backwards at first.. and the Hyd clutch setup...
Old 05-16-2011, 09:56 AM
aussiebj's Avatar
The first trial fit ...And now she fits like a glove.. there will be some fabb work on the drivers header and a custom steering shaft will be made ..and the whole assembly will be detailed once its in there for good ...but for now it looks like it is supposed to be in there.
