Old 05-25-2011, 01:53 PM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
Originally Posted by Chris442 View Post
If you want to run those three things, you'll need 3 senders. It's worth noting that the ECU is capable of PWM fan control; all Corvettes have had it since 05. I have this set up with an LS7 in a '68 Camaro. I also use an A/C pressure sensor for the computer to run the fans for that. Without going into too much detail, you'd need the PWM module from a Corvette to make it work and be able to set, or have somebody set, the computer to work it.
that's pretty wild I did not know that. Only corvettes get that?
Scott from NJ
Old 05-25-2011, 05:02 PM
Chris442 Chris442 is offline
That's all I know about, for sure. I can say for certain that G8s, GTOs and new Camaros don't have it, though. Based on what's available in HPTuners, I'd guess it could be made to work with any of those computers, but I've never tried it.
It's been working great on the Camaro for the last 3 years and 15k+ for me. With the big Ron Davis and dual Spals, you rarely hear the fans run, since they're almost never at 100%.
Old 05-25-2011, 10:10 PM
I have a DCC in my car and even with one of the fan motors having a bad bearing I still don't hear them. At idle on a 90* day they hover around 6-7 volts. I had no idea GM was using PWM.
Scott from NJ
Old 05-26-2011, 10:29 AM
68ZClone 68ZClone is offline
Any reason the fan controller from Dakota Digital would not work?
http://www.dakotadigital.com/index.c...641/prd641.htm
NCSU MSME 2005
1968 Camaro
350
4-speed
-under re-construction
1989 Camaro RS
Old 08-02-2011, 12:01 PM
ModernMuseum ModernMuseum is offline
Ok, in tying up some loose ends, I decided to just use the sending unit that came with the Dakota Digital and install the sensor in the radiator line.
Do I install it in the large 1.5" line or the smaller 1.25" line? I almost pulled the plug on a 38mm adapter (1.5"), but then remembered that I don't know which line I have to install it in!
Here's a decently priced one for $25.
Old 08-02-2011, 01:32 PM
I guess I should clarify...should it be the upper or lower radiator hose?
Old 08-02-2011, 04:31 PM
the upper hose is water returning from the engine to the radiator and would be the one to use.
Old 08-02-2011, 05:06 PM
That's what I thought. Thanks Jody.
