Thanks, quite a bit done today. Finalized the electrical system setup with the rear moutned battery. We should have that in in a couple of weeks. The welder finished most of the valve covers and the evac system. Also got the water pump bracket roughed in. Going to mount it along the passenger side frame rail where the battery came out using battery tray holes. Running the outlet down through the frame and bending it 90 degrees into the engine compartment.
