Old 02-14-2006, 12:00 PM
almcbri's Avatar
almcbri almcbri is offline
Originally Posted by Derek69SS
I think you meant coil-springs
Of course, new springs & shocks like Marcus suggested, and for the rear, if you want mild, replace the bushings with new rubber bushings... if you want something more, UMI makes lower arms with QA1 spherical ends on both ends, adjustable uppers, again with QA1 sphericals... then there's Wolfe Racecraft, which makes spherical bearings that go in the axle housing also.
I bought my whole rear setup from Wolfe, but they have all solid rod-ends rather than the teflon-bushed QA1s, which would help isolate the road-noise and vibrations. Their lowers also do not allow for a sway-bar.
Derek,
yeah I was still asleep when writing that response. "Coil Springs"
1968 Camaro LS1/T56, Hotchkis Springs, Tubular Arms, AFCO sway bar, C5 brakes, VWW 18" V40's http://s14.photobucket.com/albums/a3...1968%20Camaro/
