Old 06-18-2011, 08:51 PM
Originally Posted by bdahlg68 View Post
Lots of plug welding and sanding later, the cowl is in and so is the DSE fill plate. Still some plug welds to do and some places to weld on the fill plate.
Question! Do I really need to tack every single spot, ors every half inch ok???
I TIG welded the one I just did with Silicone Bronze rod -- it's low heat makes it ideal for NON structural --- but since you cut the old one out - you need to have some structure - I'd weld it solid - just watch your heat. You're going to have to bodywork that big flat area one way or the other if you want it to look good.
Old 06-18-2011, 08:54 PM
I went back to look after posting -- and I see that you're probably asking about the DSE panel -- again - I welded the one I just did solid as I stated above...
I thought maybe you were asking about the cowl to firewall....
Either way -- solid is good - probably overkill -- but I don't want to go back to fix a cracked paint job!!
Old 06-18-2011, 09:24 PM
Ron Fox's Avatar
Ron Fox Ron Fox is offline
Blue Bird
Nice build!
Ron
1969 Firebird, 4-speed Coupe
Old 06-19-2011, 05:22 AM
bdahlg68's Avatar
bdahlg68 bdahlg68 is offline
Thanks for the input. I'm going to weld it up solid. A stitch in time saves nine, right?
Brian
1968 Pontiac Firebird
1989 Ford Mustang
Old 06-21-2011, 06:25 PM
bdahlg68's Avatar
Baby steps. Drivers side drip rail is welded in and quarter and roof test fitted.
Passenger side is next!
Brian
1989 Ford Mustang
Old 06-21-2011, 11:21 PM
cencalc6 cencalc6 is offline
nice job
Old 08-05-2011, 06:44 PM
bdahlg68's Avatar
A small update....
Passenger side drip rail is welded in. Panels were test fitted and I'm happy so far.
Trunk pan removal has started
DSE tubs are here
JRS front suspension is ordered and should ship next week!
5.3 LM7 truck engine free of charge has been found (just have to ship it in)
Engine build plans are under investigation. Debating stroker kits and top end packages. Targeting around 500hp at the crank. Truckin magazine did a good project with the LM7 and went through all these options so I'm using that as a bit of a guide.
With the baby here there hasn't been any time to do much actual work to the car over the last six weeks (actually none). Maybe some spare time will arise soon!
Brian
1989 Ford Mustang
Old 10-01-2011, 02:24 PM
bdahlg68's Avatar
JRS Apex C6 Front Suspension is in... took a bit longer than planned to get it here, but it's here. Still missing a few bits and pieces, but I test assembled most of it this weekend. Once I get the missing pieces, the frame will go for e-coat and final assembly will be done. Overall the quality seems pretty damn good, especially on the frame. Some long and impressive welds.
Brian
1989 Ford Mustang
