Old 07-02-2011, 10:01 AM
Fluid Power's Avatar
Originally Posted by jocko124 View Post
Looks like I'm going with the McLeod 1400-30 unit.
Please don't. I had 2 and ended up with a RAM unit. Tons better.
The Mcleod leaked right out of the box....Twice! I will give you the one I just took off if you enjoy that kind of punishment.
Seriously. They are junk.
I used a RAM unit that mounts using the stock bearing retainer. (TKO 600) Straight forward to install. Take a lot of measurements and then shim accordingly.
http://www.ramclutches.com/Products/...se_bearing.htm
Hope this helps. If you have any questions, ask away.
Darren
Old 07-02-2011, 12:13 PM
jocko124 jocko124 is offline
Darren
Thanks for the heads up Darren. I'll have to do some more research to see if RAM makes them for the Ford T-56 Magnums (vs the GM T-56's). I have the stock GM TO bearing which is supposed to be pretty reliable and is much less expensive than the McLeod---but it doesn't fit.
Lee
1966 Cutlass
The difference between truth & fiction: fiction has to make sense.
Build Thread:
https://lateral-g.net/forums/showthread.php4?t=31963
Old 07-02-2011, 07:46 PM
It looks like they do for the 05-08 mustangs. But not sure that helps at all. Break off a phone call. Their tech support is great.
Darren
Old 07-02-2011, 07:55 PM
Thanks, I'll look into it.
Lee
1966 Cutlass
Build Thread:
Old 07-03-2011, 09:25 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
Forgive my ignorance, but why is everyone purchasing aftermarket TO bearings rather than GM units?
Matt
Old 07-03-2011, 09:39 PM
Matt
In my case Matt, the GM unit will not fit because I have a T-56 Magnum for Ford applications.
Lee
1966 Cutlass
Build Thread:
Old 07-04-2011, 11:40 AM
Ron in SoCal's Avatar
A few months ago I picked up Mcleod PN 14-302 for the T56 Magnum. I hope it works better than what you guys have experienced cause pulling the tranny multiple times is no fun!
Ron in SoCal
69 Camaro in progress
Old 07-07-2011, 07:49 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
Darren
Darren, which one of these from RAM did you use? When I clicked on the link, the page has like a million of them.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 07-08-2011, 05:25 AM
I used the 78125HD. Available from Summit/Jegs or where ever you prefer to buy speed parts. The 78125 is available as well. The difference according to the tech guy at RAM was beefier o-rings. As both Mcleod's leaked, I was all for beefier O rings. I am running a GM crate 383, and TKO 600. a pretty mild combo in this crowd and it works perfectly. It is a little tricky to install as one must install and keep it inside the bellhousing, stab the tranny thru the RB.
My experience with Mcleods was a joke. The second install, the bearing squealed like crazy. When I called tech support, he said "it will wear in." Sure. that makes total sense. Every bearing squeals before it wears in.... And yes my math was done correctly. I even bought another pressure plate so the air gap was dead on.
Just Google 'mcleod release bearing leaking.' and start reading...
Darren
