Old 07-21-2011, 07:04 PM
Originally Posted by scherp69 View Post
Thanks Jody. So basically I should always keep turning the engine over clock wise? Then once I have the lifter's max lift point, zero the dial and keep turning the engine over clockwise until I get 50 degrees on either side of the max lift? Does that make sense?
no, you can back up for the ramp side measurements, just make sure to go far enough past where you're going to measure from that you've taken the slack out of the chain when you reverse directions and go clockwise again. After finding and verifying TDC and setting the pointer/wheel to "0" I run the engine clockwise to max valve opening. I back it up counter-clockwise maybe half a turn down on the dial indicator (180 degrees) and then rotate clockwise to 50 degrees before max lift, record the reading, and continue on to 50 degrees after. From there adding the two numbers and dividing by two gets you the lobe center.
Old 07-21-2011, 07:59 PM
scherp69's Avatar
scherp69 scherp69 is offline
I got it now. Thanks Jody. I'll try that on Tuesday when I get to head back out to the shop. So is that what they are doing when they mention in the article to go to 60-70 degrees and then back to 50 degrees?
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 07-21-2011, 08:13 PM
yeah, they just want you to go back past where you'll be measuring, so all the slack is taken out when you go back clockwise to the measuring point.
Old 07-23-2011, 08:13 AM
scherp69's Avatar
Thanks for the help Jody. It actually sounds a lot easier now.
Mike
New Gen Splitters
LS3 and TKO600
