View Poll Results: What engine will you be using?
SBC w/ EFI 42 7.00%
SBC w/carb 98 16.33%
BBC w/ EFI 41 6.83%
BBC w/ carb 50 8.33%
LSx 204 34.00%
LSx w/ forced induction 80 13.33%
Other 70 11.67%
SBC w/ EFI & Forced Induction 15 2.50%
Voters: 600. You may not vote on this poll
Old 06-03-2011, 09:35 AM
hud697's Avatar
hud697 hud697 is offline
6.0 Lq4 block (final cubic inches yet determined) L92 heads, stock Ls3 intake and a wooden cam
Old 06-03-2011, 03:37 PM
OVRKILL's Avatar
OVRKILL OVRKILL is offline
ahahaha...you'll get plenty of ideas over here! We like to go around corners...
I'm going to have a hard enough time going straight let alone having to worry about the twisties!
Sorry, but I'm the real "Flash" over here, right Ron?
That is a stupid sweet motor ya got there.
Lol, yep. You were the "flash" I got when I searched. Thanks for the compliment....should be fun.
'01SS - RHS 460
Fikse / MWC / Kinsler / Mast
Enough torque to buckle pavement!
"Went right past silly and all the way to stupid..." - Shawn Miller
Old 06-03-2011, 05:52 PM
fleetus macmullitz's Avatar
Old 06-03-2011, 11:37 PM
Why do you guys only have ONE motor......
Old 06-21-2011, 10:02 PM
Cuz we're into appearances. Turns out motors look better in a the car rather than on a floor.
Old 07-26-2011, 01:32 PM
sweetstang68347's Avatar
sweetstang68347 sweetstang68347 is offline
SBF
*hears crickets chirp in the background
Old 07-31-2011, 07:24 AM
Lowfast's Avatar
Lowfast Lowfast is offline
Ford all Aluminum 4.6 3-valve in my 65 Falcon. Already picked up stage II ported heads and cams. Plan for a mild 450hp NA, if that ever becomes boring I will step it up with a procharger.
Old 07-31-2011, 03:55 PM
70rs's Avatar
70rs 70rs is offline
388 sbc stroker.
Carb
Spark plugs
Water pump
Starter
Intake
Alternator
Distributor
Coil
Wires
And some bolts to hold it all together.
388, 4 bolt GM block, steel crank, 5.7" rods,
Speed pro coated pistons (hyp) , moly rings
H series rod and main bearings
Melling HV oil pump (blueprinted)
Hyd roller cam (tbd)
Comp hyd roller lifters (retro fit)
Perf RPM air gap
Holley 750 dp
RHS iron 180 / 64cc heads
Bronze guides
2.02/1.60 stainless valves
Comp magnum push rods, guide plates
Comp springs
Roller rockers
Flow Cooler hi flow w/pump
Alum radiator
MSD Pro billet dizzy, 6AL Box
Mallory wires
ARP fasteners throughout.
T56 6 speed
Centerforce billet steel flywheel
Centerforce clutch (tbd)
Hyd T/O brg
The goal is durability , broad torque curve, decent street mannors, and a big stupid grin every time I stomp the go pedal. Nothing fancy, just reliable and fun.
Eric
Old 08-11-2011, 12:05 AM
wellis77's Avatar
wellis77 wellis77 is offline
Viper V10. Stock to begin with but will get a tune. Eventually a cam, head and intake work, and a set of roller rockers. Will have custom headers and full 3" exhaust with hi-flow cats immediately.
Will Ellis
Project SCUD, 1969 Dodge Dart Swinger, 1/2 Dart / 1/2 Viper
Old 09-22-2011, 07:17 AM
OVRKILL's Avatar
*edit....."I'm going to have a hard enough time GETTING IT TO FIT....." . Anyone looking for a 850hp-ish N/A bullet for their build
'01SS - RHS 460
