Old 08-01-2011, 05:20 PM
Rick D's Avatar
Rick D Rick D is offline
Welcome to the site, and this topic has been beaten to death. Try using the search at the top of the fourm. That should give you at least 2 days worth of reading. Also post up some pictures of your ride in the project section.
Rick
Old 08-01-2011, 07:01 PM
3_z28camaro's Avatar
3_z28camaro 3_z28camaro is offline
Two of the most popular and proven rear suspension setups are from DSE and AME. I will be using he Art Morrison rear setup since it replaces those weak stamped rear frame rails. Both are triangulated four link and very capable.
http://artmorrison.com/homepage.html
http://www.detroitspeed.com
1971 RS Camaro
Old 08-04-2011, 09:58 PM
Normally a 4 bar has very little adjustments where a 4 link has more.Have you looked at a 3 link or torque arm set up? Like http://www.speedtechperformance.com/...rod/prd170.htm or http://www.jakesrodshop.com/Products.html or a bolt in one https://securec20.ezhostingserver.co...id=25&catid=77
Old 08-06-2011, 04:37 PM
69-er 69-er is offline
What's everybody's opinion on this?
http://cgi.ebay.com/ebaymotors/67-69...Q5fAccessories
How can it be so much cheaper than the others mentioned above? The guy has a lot of positive feedback.
Old 08-06-2011, 04:46 PM
Ron in SoCal's Avatar
^ that is a drag race set up. Really good for planting the rear on fast starts, not so good for going around corners.
Ron in SoCal
69 Camaro in progress
Old 08-06-2011, 04:47 PM
I read that 4 bars are considered more for street use, (corners) and 4 links were for drag racing.
Old 08-06-2011, 05:07 PM
You might be right, but that looks like a 4 link to me. Ask the seller his intended application, get some stats (AS%) and see what he says...
Ron in SoCal
Old 09-09-2011, 07:52 AM
BMR Sales's Avatar
If adjustability & ease of installation is as important as performance a Torque Arm is something to look at. There are many systems out there and most are well worth using, but the key to a great purchase is figuring out if the system you choose meets all your needs and goals.
Old 09-09-2011, 01:14 PM
Lateral-g Moderator
DSE has a system that works great. Handling and ride. The ride and handling of my blue 69 was fantastic with their quadralink. It's beaten on and proven weekly by their test cars or by some of the other fast guys driving around here. Go take a ride with them.
