Closed Thread
Old 08-03-2011, 12:35 PM
skatinjay27's Avatar
Originally Posted by sweetstang68347 View Post
Maybe a little off topic but how does everyone know everyone else? Are you guys in the same location or just attend the same events. Sometimes it sounds like a car can be pushed across the street to the next shop if you know what I mean.
for me unfortunately for me i gotta live in the same city as todd ! but we did end up meeting through this site. for others its like he said sema and other events (just spend more time here and before you even meet others youll feel like you've known them for years!)
yo iceman when u putting it back in ?
AJ
  #2392
Old 08-03-2011, 02:07 PM
Dear Crew Chief Whitesides,
Hoping the parts come in today and I can start assembling the trans. I have another trick up my sleeve so it may delay the install a little while. You are still welcome to come over Sunday. There is work to be done and lots of **** to be talked.
  #2393
Old 08-03-2011, 02:08 PM
Originally Posted by Payton King View Post
I have a pro 5.0 on a T56. The stops work, but they are harsh to the hands. I have taken mine out. You may try putting some type of rubber on the end of the bolts to lessen the shock. You will understand the first time you bang the gears.
I'll wear gloves.
  #2394
Old 08-03-2011, 04:45 PM
No one likes a c0cktease.
  #2395
Old 08-03-2011, 10:23 PM
Don't worry, my giggle juice will just negate your clutchless tranny.
  #2396
Old 08-03-2011, 10:41 PM
Turning the corner and have all the surfaces and parts cleaned and dissasembled the main shaft to inpsect the components.
For those of you with TKO's that leak when they sit in the garage, here is what causes it. The lower shaft plug that houses the end bearing race has a tiny little o ring on it. I made a video but I'm not in the mood for the ridicule. Anyway, the oring is a little chewed up. Seems to me that teh plug spins from time to time and compromises the oring. I'll be gluing mine back in with silicone and a new oring.
If you can't find em, grind em. We all know and have experienced this deal. Well, my inspection of the main shaft gears, synchros, and slides made this all to real. The third/fourth gear slider needs replaced. It's hard to tell, but the teeth should be sharp and they are beat up.
My parts did come in today but now I'm waiting on the slider before I can reassemble the main shaft. I did replace the pins in the shift forks as they tend to get bent and one was a hair tweaked. I reassembled the 5th gear assembly with the needle bearing fiasco. This is the only carbon fiber that will ever be part of this car.
  #2397
Old 08-03-2011, 11:32 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
Hey Todd, want to rebuild a T56?
I'm continually amazed by the projects you keep on undertaking,
Matt
  #2398
Old 08-04-2011, 08:32 AM
Let's see how this one goes first.
  #2399
Old 08-04-2011, 06:45 PM
Track Junky's Avatar
I'm probably the last guy that would ever want to tell you this but you are the man. Great effort dude!!
If she dont hold up in September I'll probably be as pissed off as you will,.
Gaetano Cosentino
  #2400
Old 08-04-2011, 07:00 PM
Are the carbon fiber syncros upgraded or standard parts?
Closed Thread
