Old 08-07-2011, 05:34 PM
Croaker's Avatar
Croaker Croaker is offline
If you're running a boosted application and you're already fuel injected, you can always set up the system with a fuel composition sensor and just dial the boost back when you don't have access to E85. I know White Racing and Marine has the ability to set up FAST, BS3 and Accel to work with flex fuel. I'm sure they're not the only ones around with the capability.
Old 08-07-2011, 07:20 PM
HRD's Avatar
HRD HRD is offline
I wonder what the OEM do differnetly (if anything) on the lines and other parts for the flex fuel vehicles to make them Ethanol compatible.
