Old 08-04-2011, 11:31 PM
groovyjay's Avatar
groovyjay groovyjay is offline
Good To see your project here too. It's going To be spectacular.
Old 08-05-2011, 06:01 AM
lilcraigford lilcraigford is offline
That rendering is awesome! Really looking forward to seeing this one come together.
Old 08-05-2011, 08:06 AM
Payton King's Avatar
Default The shot on she devil
is there no adjustment for roll center change on the watts?
Old 08-05-2011, 03:26 PM
kyle_newman's Avatar
kyle_newman kyle_newman is offline
Great project! Love to see the midyear Vettes! What will you be doing for a chassis and suspension?
Kyle Newman
Fabricator @ Newman Car Creations
55 Chevy Newman Car Creations chassis C4 front and independent rear, LS3 376/480, T56
57 Chevy wagon Newman Car Creations chassis, C4 front and independent rear, LT1, T56
www.newmancarcreations.com
Old 08-05-2011, 04:00 PM
MattG's Avatar
MattG MattG is offline
Hint Hint!!!!
'69 Camaro Coupe, Full Ridetech stage 3 suspension, moser wavetrac 12bolt, Forgelines, Ls3 Heads/Cam,T56 Magnum. Built by me and tuned by Ed!
'69 'Vert Camaro: DSE Sub-Frame, DSE Mini-Tub, DSE Four-Link w/9inch. LME LS7 427, T56. Tuned by Ed Hutchings, :SOLD!
Old 08-05-2011, 08:36 PM
Hdesign's Avatar
Hdesign Hdesign is offline
Thanks for the plug and thanks again for the opportunity to help on this one Ty. We'll dial this one in in the next several days!
Ben Hermance
Hermance Design
My Facebook
Old 08-06-2011, 04:12 PM
tyoneal's Avatar
tyoneal tyoneal is offline
Payton:
Good eye!
No not yet, there are still several things I need to get done for the suspension to set it up properly, that being one of them, I also wanted to go with a full floating rear end. (I should have tried to buy Mark's when I had the chance)
When I get back on this car, and get the front subframe in, I'll get the rest of these issues taken care of.
When I was working on it, it became apparent that some of the additional features I would like on this car would have to wait until a later date. For instance getting the front weight jacks became a bit difficult to justify for the amount of movement you actually get out of them. I figured that since I was going to be the primary driver, and have access to weight jacks in the rear, I'd already be starting with easier adjustment than I had before.
Another item I found challenging was finding the right person to install the adjustable sway bars. I had never done it before. I spoke with HRP World, and they would help make sure the right parts were measured correctly and ordered, but that was as far as they could go. I still would like to implement these on the car, but until I get back on it full time, and find the right shop here locally, I will work with the one on there. Who knows it might not need any adjustment.
(http://www.hrpworld.com/index.cfm?tp...action=product)
I know this is a lot more information than you asked about so sorry about that.
I do appreciate anything you see that you think needs to be brought to my attention, thanks for doing so.
Project, "EnGULFed"
Ty O'Neal
"She Devil" aka. Betty
1969/70 Camaro SS
427 LS3, 600
Keisler Road and Track T-56
"Chester's '65"
1965 Buick Riviera
Old 08-07-2011, 01:47 AM
tyoneal's Avatar
Originally Posted by MattG View Post
I've got your very nice differential on the frame. It looks like art and I understand I probably won't have to worry about breaking it.
I look forward to putting it through it's paces.
Ty
Project, "EnGULFed"
Ty O'Neal
1969/70 Camaro SS
427 LS3, 600
"Chester's '65"
1965 Buick Riviera
Old 08-07-2011, 08:41 PM
tyoneal's Avatar
Kyle:
Funny you should ask that!
It is a C4 based design. The Frame was built by Mid-America, The front end suspension, Rack and Pinion, and Brakes are straight C4.
In the rear is a complete Newman rear end. The half shafts have been narrowed so the rear wheels can have a bit more dish/width. Brakes are C4 with cooling disk already installed. It has a Tru-Trac Carrier with 4.10:1 ring and Pinion gears in the rear.
Hopes this helps.
Thanks for your interest.
Ty O'Neal
Project, "EnGULFed"
Ty O'Neal
1969/70 Camaro SS
427 LS3, 600
"Chester's '65"
1965 Buick Riviera
Old 08-07-2011, 08:43 PM
tyoneal's Avatar
Thanks Ben, I look forward to it.
Ty
Project, "EnGULFed"
Ty O'Neal
1969/70 Camaro SS
427 LS3, 600
"Chester's '65"
1965 Buick Riviera
