Old 08-06-2011, 03:52 PM
dwfastcam dwfastcam is offline
Oh yeah, what are you going to do for front sway bar? Splined?
Old 08-06-2011, 05:01 PM
LM7_67 LM7_67 is offline
Originally Posted by dwfastcam View Post
Awesome project! I dig that your notching the frame. What is the width and offset of that front zr1 rim? What spacer did you use? Can't wait to see more updates.
it's 9.5" wide. offset is stock 4th gen Camaro. currently using a 1.5" spacer.
yep.
1967 Camaro - LM7, T56, TVS, 12.7:1
1996 Impala SS - DD
Old 08-06-2011, 07:19 PM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
Tom have you done a track day with that yet or just auto cross?
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
Old 08-07-2011, 10:00 AM
Closest thing I've done to a track day is the RTTC2 course. I'm trying like hell to make it in Sept. but I'm starting to have my doubts whether it'll be together by then.
1996 Impala SS - DD
Old 08-07-2011, 09:05 PM
Tuske427's Avatar
Tuske427 Tuske427 is offline
Originally Posted by LM7_67 View Post
Time for updates!
After I covered my car with mud Saturday morning spinning out on the road coarse, I hosed it off and I thought I got most of the mud off. But I was wrong. This stayed with me all through the rest of Saturday, all of Sunday, and a 400 mile drive home.
I was there that Saturday. At least you can say the track was cold and wet from the crisp morning condensation. The folks who spun out later that day didn't have that option...
Long Live the Muscle Car
https://lateral-g.net/forums/showthread.php4?t=26338
Instagram: @tuske427
Old 08-08-2011, 08:19 PM
Chicane brackets showed up last Friday. Working on the ideal position that gives maximum room for the coil-over while still clearing the UCA.
Using a super high-tech wooden dowel to mock up the sway bar. Bending the arms is going to be a blast...
Mid-September finish date is looking pretty shakey at this point. We'll see how things go.
1996 Impala SS - DD
Old 08-08-2011, 08:40 PM
Kickin a@@! So your getting the speedway kit and bending the arms up for the high clearance radius?
Old 08-09-2011, 05:35 AM
coolwelder62's Avatar
Look's Awesome,Keep up to great work. Scott M.
Old 08-16-2011, 08:21 PM
Updates!
Got all the parts for the sway bar last friday. The arms will be bent to follow the contour of the frame and then shortened to the correct length.
Also got the springs last week. Plenty of clearance to run the sway bar arm around the spring.
I did run into one issue however. Compare the next 2 pictures....
Now, looking at some pictures, and from what I remember, the balancer might still just clear the tubular sway bar. If it doesn't fit, even with shimming it lower a bit, the old Hotchkis bar will bolt right in place. I'll lose some turning radius, but at least it will work until I can figure out another solution.
Also, talked to the guy who I'm going to have weld everything back together. He did not seem optimistic about my time line lol.
1996 Impala SS - DD
Old 08-17-2011, 10:13 PM
482supersnake 482supersnake is offline
Default Sway bar details.
Hi. Was the sway bar a custom ordered piece? If so what type of material is it (chrome moly, or mild steel). I am working on something like that for my Mustang and any info would be a great help. Thanks Scott
