View Poll Results: What chassis coating would you use?
Paint 38 23.17%
POR-15 27 16.46%
Powder coat 89 54.27%
Other 10 6.10%
Voters: 164. You may not vote on this poll
Old 08-15-2011, 07:28 AM
wmhjr wmhjr is offline
Normal paint. On semi-gloss black powdercoated paint, just semi-gloss duplicolor worked perfectly. First touch up 2 years ago. Still perfect today.
Again, if it's a Ridler ISCA indoor show car then it's a different story. However if it's anything else, and in particular if it's one of the "normal" chassis colors (like gloss, semi-gloss or flat black, or silver) then I still scratch my head every time somebody says you can't touch up powdercoating. Heck, I've been touching it up on other stuff for at least 10 years. I don't get it.
Old 08-15-2011, 09:31 AM
ccracin's Avatar
ccracin ccracin is offline
Yea, but your dealing with a RACE car, not a normal street car!
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 08-15-2011, 10:13 AM
It's a pretty shiny race car, though
Old 08-23-2011, 10:07 AM
syborg tt's Avatar
Here are my thoughts
Chassis - POR or Paint
Why: Most frames need a little body work and you can't powder it once it's body worked.
Anything that bolts to the chassis - Powder
marty-mj
Old 08-23-2011, 10:17 AM
I don't understand what you're saying. What do you mean by "most frames need a little body work"? Assuming that the frame is off the body to start with (otherwise powder isn't even an option). Or is it that you still believe for some reason that you can't touch up a powder coated frame if you need to modify it? Just trying to understand the logic here.
Old 08-23-2011, 10:19 AM
syborg tt's Avatar
Rust & pitting in most cases
New Frames - not needed
marty-mj
Old 08-23-2011, 10:31 AM
OK, so exactly what is different about elimination of rust and/or pitting that makes powder undesirable? If you are prepping the frame to begin with (dipping, blasting, etc) then what's the difference? Let's face it, if you're using POR, then you're not going for a super smooth attractive finish. I'm still not understanding what you're saying.
Old 09-17-2011, 02:20 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
I have a question that is slightly off topic. First, let me say I prefer powdercoat myself. I too, will powdercoat everything I can...i.e., frame, control arms, brackets, rear end, etc. Now, the question I have is...other than powder, paint and POR, what in the hell is the "other" option that some of the guys are voting for? Didn't know there was anything else you could do other than the three aforementioned choices.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 09-17-2011, 08:29 AM
out2kayak out2kayak is offline
For other, I was thinking some sort of plating (chrome, nickle, etc.), aluminizing, or some other similar process.
As well, I suppose you could wrap it in Kevlar.
Bottom-line is that you are only limited by your imagination and pocket book.
-- Joe
Old 09-18-2011, 03:25 PM
Nikwho Nikwho is offline
My plan is to prime the frame with epoxy primer after cleaning to bare metal then spray with the Eastwood 2k Ceramic Chassis Black. I am going to use gloss black. All components like rear axle and suspension arms, a-arms, spindles, steering components, tranny cross member etc. are getting powder coated.
