View Poll Results: What chassis coating would you use?
Paint 38 23.17%
POR-15 27 16.46%
Powder coat 89 54.27%
Other 10 6.10%
Voters: 164. You may not vote on this poll
Old 08-23-2011, 10:07 AM
syborg tt's Avatar
Here are my thoughts
Chassis - POR or Paint
Why: Most frames need a little body work and you can't powder it once it's body worked.
Anything that bolts to the chassis - Powder
marty-mj
Old 08-23-2011, 10:17 AM
wmhjr wmhjr is offline
I don't understand what you're saying. What do you mean by "most frames need a little body work"? Assuming that the frame is off the body to start with (otherwise powder isn't even an option). Or is it that you still believe for some reason that you can't touch up a powder coated frame if you need to modify it? Just trying to understand the logic here.
Old 08-23-2011, 10:19 AM
syborg tt's Avatar
Rust & pitting in most cases
New Frames - not needed
marty-mj
Old 08-23-2011, 10:31 AM
OK, so exactly what is different about elimination of rust and/or pitting that makes powder undesirable? If you are prepping the frame to begin with (dipping, blasting, etc) then what's the difference? Let's face it, if you're using POR, then you're not going for a super smooth attractive finish. I'm still not understanding what you're saying.
Old 08-23-2011, 12:18 PM
syborg tt's Avatar
Ok my choice would personally be bodywork and paint. Not POR becuase it isn't baby butt smooth.
I've seen shops powder a frame then smooth out the ruff spots and then paint it.
Unless you have hours upon hours to smooth ( metal work ) a rusty frame that you are trying to make look semi-show quality Powder isn't the way to go.
?? are you from Cali by any chance
marty-mj
Old 08-23-2011, 02:11 PM
Nope. Not from CA.
If you're trying to build a total show car frame that will be suspended and have mirrors and lights under it, then paint is the only way to go. But then, you're not driving the car and CERTAINLY not "pro-touring" the car. I'm talking about high end custom paint.
How many people here are smoothing their frames to remove all pits and marks? 1%? 3%? My build competed (and won) in multiple ISCA shows. The frame was original, got sandblasted, I did some welding for reinforcement, and it got powdercoated. And that stuff is TOUGH. The other thing is that powder is thicker, and fills many of the imperfections that paint will not.
Guess we'll just agree to disagree, but the only 3 times I'd recommend paint over powdercoat are:
1) If you're building a total, all out, indoor ISCA show car that you're not planning to drive much.
2) If you have no money at all and do not have a reasonable powder coater in your area.
3) If you cannot pull the body off the frame.
Old 08-23-2011, 03:56 PM
56pickup's Avatar
56pickup 56pickup is offline
I agree 100%
Tyler
Old 08-23-2011, 07:58 PM
syborg tt's Avatar
Actually I agree with you. I like/love powder and your right most people don't need the Show Car look. I am going to powder most everything that I can on my car. The goal is to take it out and beat the crud out of it and Powder can withstand the abuse.
A good friend Powder a Mountain Bike Frame almost 15 years ago and I've beat the crap out of it and there isn't a chip on it. Plenty of dents - no chips.
Nope. Not from CA.
marty-mj
