  #26
Old 08-28-2011, 10:00 AM
Sieg's Avatar
Sieg Sieg is offline
Originally Posted by LarryC5 View Post
Sieg,
Looking very good! I'm about to start on one myself. Are you considering making removable in the event you need to service the shifter?
Larry
Current plan is to make studs out of panhead allen bolts, grind the heads flatter and tack them to the tunnel or a plate that gets tacked to the tunnel. For the console center mount I'll tack a similar stud on the tunnel cover and use a rubber spacer to set the height. The tunnel will be covered with Dynamat Extreme, I may double layer the tunnel where the cover flange contacts, that will add a little clearance and insure a good seal.
