Old 08-30-2011, 01:54 PM
70rs's Avatar
70rs 70rs is offline
If I remember right the Air Raid brand boxes are sealed on top. I think you could add a "scoop" or intake of some kind around the grill or headlight and make it a pressure fed system. (maybe under the bumper or between the bumper and grill?)
I have the K&N style CAI. And it did make a difference, but the top edge of the filter enclosure does not seal tight to the hood. That really minimizes any benefits I should be seeing. One thing it did was make the intake a lot louder. But only when I really have my foot in it.
I am interested to hear what they say about the headers. I have not done anything with my exhaust yet but plan to this year. I want to see what system offers the most improvements.
Eric
Old 08-30-2011, 02:02 PM
johnnymac46's Avatar
johnnymac46 johnnymac46 is offline
Originally Posted by Gonzo View Post
One more pic!.. should grab plenty of cold air..
Light @ the end of the tunnel! Almost done with the cold air box..
Last night we spent a few hrs working on the billet grill inserts.. Figured the car got billet tail lights .. Might as well give it some billet grill inserts.. adds balance to the custom work on the front & rear of car
I found it....only mine wont be as complex or magnificent....it was Chris at JCG didnt mean to short change you on the credit.
Last edited by johnnymac46; 08-30-2011 at 02:05 PM. Reason: I forgot to give credit when it is due
Old 08-30-2011, 04:48 PM
70rs's Avatar
That should do it!
Eric
Old 09-06-2011, 07:48 PM
So after a lot of thinking and paper design I have come up with a cross between the above design (chris-JCG) and the Spectre Proformance intake set-ups.
Lowering the radiator will require a lot of cutting re-engineering and extra work.
So I found a unit that uses a dual inlet but I really dont like the look of it so Im trying to put my own spin on the design.
My design will be two scoops I have made up that will fit in between the headlights and outside the radiator. The intake tubing will run between the lights and radiator, turn inboard and meet up with a "Y" then to the MAF and into the Throttle body. It works in my brain.
I'm going to take the scoop I have designed to a local custom Sheet Metal shop. They have all the CAD programs and we should be able to figure out a way to machine the scoop into two pieces to hold the Filter (K&N 33-2085). I left a two inch section in the scoop which should be plenty of room to machine for the filter and find a way to bolt the two halfs together. I'm planning to use steel to keep the price down, but we'll see where we end up.
I have a couple of questions.
- How will rain effect the performance of the intake system? is there something I should/can do to mitigate any issues? This is my daily driver so not driving in the rain isn't an option.
- Is it worth it? I could just go with the a aftermarket set up but that takes the fun out of it. I am open to suggestions or any advice anyone may have I've never built an intake before so criticism is welcome
