Old 08-30-2011, 07:55 PM
FP69's Avatar
FP69 FP69 is offline
Thank you!
Old 08-30-2011, 08:23 PM
70rs's Avatar
70rs 70rs is offline
Originally Posted by Frank Palmeri View Post
Thank you!
No problem. I think it will come down to spring diameter and whether or not they will fit your spring pockets. Good luck, let me know what you find out.
Eric
Old 08-31-2011, 05:05 AM
FP69's Avatar
Have you used those twist in coil spring adjusters?
Old 08-31-2011, 05:46 AM
70rs's Avatar
No. Not on any car I owned. I don't know how safe those are.
Eric
Old 08-31-2011, 06:45 AM
Track Junky's Avatar
Call Global West Suspensions and ask for a set of their Polyurethane lower control arm spring bases. They have a pocket for the cut portion of the spring and will raise front approximately 1 to 1 1/4"
I'm not 100% sure they will work with stock lower control arms but its worth a try to call and ask.
Gaetano Cosentino
Old 09-02-2011, 04:34 AM
FP69's Avatar
will do... thanks
Old 09-04-2011, 09:03 AM
David Pozzi's Avatar
Global west sells a thinner aluminum spacer that fits in the spring seat. You need a 3/8" thick spacer to raise the front 3/4".
http://www.PozziRacing.com
